Aller au contenu principal
RedOctane X-Plorer Rear Case Replacement
Ce dont vous avez besoin
  1. RedOctane X-Plorer Rear Case Replacement, Rear Case: étape 1, image 1 de 2 RedOctane X-Plorer Rear Case Replacement, Rear Case: étape 1, image 2 de 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Rear Case Replacement: étape 2, image 1 de 3 RedOctane X-Plorer Rear Case Replacement: étape 2, image 2 de 3 RedOctane X-Plorer Rear Case Replacement: étape 2, image 3 de 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Rear Case Replacement: étape 3, image 1 de 3 RedOctane X-Plorer Rear Case Replacement: étape 3, image 2 de 3 RedOctane X-Plorer Rear Case Replacement: étape 3, image 3 de 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
Riley
Membre depuis le 04/18/18
649 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team S17-G1, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 565
