Introduction
Utiliza esta guía para reemplazar un disco duro muerto.
Ce dont vous avez besoin
Vidéo d'introduction
Extrae los siguientes diez tornillos:
Tres tornillos Phillips #00 de 14.4 mm
Tres tornillos Phillips #00 de 3.5 mm
Cuatro tornillos de resalto Phillips #00 de 3.5 mm
Usa el borde de un spudger para levantar el conector de la batería haciendo palanca para extraer su toma de corriente de la placa madre.
Remueve los dos tornillos Phillips que sujetan el soporte del disco duro a la tapa superior.
Retira los cuatro 6,0 mm T6 Torx discos duros puestos de retención de los lados del disco duro.
Transfiere las publicaciones de retención del disco duro a su nuevo disco duro.
Para volver a ensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
438 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
32 commentaires
Under updated firmware, macbook pro unibody models will not recognize many third-party hard drives. See this discussion: https://discussions.apple.com/message/15...
Awesome guide! Swapped my 320GB hard drive for an 1TB hard drive. Took five mins thanks to iFixit!
hey, do you use SATA 3 for you’re MacBook Pro A1278? is it work good? no problems?
dimdimisra, you use the built in cable that comes in it, because of the proprietary mortherboard connector, you can’t use a regular SATA 3 cable
I feel you should be pointing out a couple of things about the chassis screws that are not obvious to the inexperienced
- the 6 screws that are not along the hinge edge of the body (4 yellow & 2 of the orange) are not perpendicular to the flat surface; they go in at an angle such that their heads are flat in the curve in which they sit. Attempting to hold the screwdriver upright in these heads could lead to damage to the screws, stripping out the "cross"
- attempting to insert these screws "straight" when reassembling will lead to cross-threading and stripping the screw threads
