Aller au contenu principal
Remplacement de la batterie des MacBook Pro 15" Unibody fin 2008 et début 2009
Ce dont vous avez besoin
  1. Remplacement  de la batterie des MacBook Pro 15" Unibody fin 2008 et début 2009, Trappe d'accès: étape 1, image 1 de 2 Remplacement  de la batterie des MacBook Pro 15" Unibody fin 2008 et début 2009, Trappe d'accès: étape 1, image 2 de 2
    • Boîtier fermé, placez l'Unibody à l'envers sur une surface plane.
    • Appuyez sur le côté rainuré du loquet de déverrouillage de la trappe d'accès de manière à saisir l'extrémité libre du loquet. Soulevez le loquet de déverrouillage à la verticale.
    The A1286 has no Access Door.!!
    I actually can see no sign of the battery!...
    aguib - Réponse
    Citation de aguib :
    I assume you have the newer model, with the built-in battery. It's still removable with tools, but these are the wrong instructions for that model.
    lgc90 - Réponse
    when will there be a guide for the other unibody macbook pro. that does not have an access door?
    irishking - Réponse
    Is there a manual to show, how disasembly the display, i mean, after step 5, to check the display between lcd and aluminiun back case?
    Max
    Max - Réponse
    On other guides you state the height of the HD that can be supported, e.g. Remplacement du disque dur du MacBook Pro 15" Core 2 Duo modèle A1211 , I have read ( but have not confirmed ) that the uni-body MacBook Pro can be fitted with the 750GB and 1TB 12mm drive from Western Digital.
    Can you confirm this?
    Many thanks in advance.
    ahothabeth - Réponse
    Citation de SHerwood Ball :
    My display and aluminum casing has separated.
    I don't know if it just snaps back together or does it need to be glued.
    I dropped mine on the carpeted stairs and the display still works.
    I'm hoping I can just snap it back together and that no plastic pieces or teeth of the snapping
    portion have been broken........
    SHerwood Ball - Réponse
    When you say "left fan" is this "left when looking at the logic board after turning the computer over and looking it up opening it up" or "left when sitting at the computer keyboard and typing on it"?
    thvv - Réponse
    We always use left and right in reference to the computer when you're using it.
    Andrew Optimus Goldheart -
    Directions were great and the worn dc in board was replaced. The hardest part of the procedure is disconnecting the data display cable. A better description of step 21 is to slide the connector parallel to the circuit board towards the outside corner. Reconnecting correctly took several tries.
    I used the tip of the spudger to nudge the corners a little at a time to seat the connector.
    The ribbon connector for the keyboard has to be inserted all the way before seating the retaining cap. It took me three tries . First try power button did not work second try numbers keys did not work.
    Thanks for the directions ...could not have done it with out them!!!
    landryd - Réponse
    Hola. Poseo un MacBook Pro Late 2008 y debo cambiarle las cornetas. Me sirve unas cornetas de un MBP Late 2011?
    jegonzalez80 - Réponse
    Please read the instructions about removing the bluetooth cable - you CAN work around it, and NOT take off the plug.
    kenneth krabat - Réponse
  2. Remplacement  de la batterie des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 2, image 1 de 1
    • La trappe d'accès est à présent suffisamment relevée pour la basculer et la retirer de l'Unibody.
  3. Remplacement  de la batterie des MacBook Pro 15" Unibody fin 2008 et début 2009, Batterie: étape 3, image 1 de 1
    • Assurez-vous que la languette de la trappe d'accès est bien à la verticale avant de commencer.
    • Tirez sur la languette et retirez la batterie de votre MacBook.
    • Si la languette n'est pas bien positionnée, elle empêchera la batterie de sortir.
    Do I need to wait for the battery to charge completely before using the computer (while plugged in)?
    Kaila Potts - Réponse
    No. You do not need to charge it completely before removing it.
    Titus (#1579) - Réponse
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
84 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
3 commentaires
I recently replaced my battery for the macbook pro late 2008 model number A1281, I have a weared problem with that - System shuts down while connected to power when it is Turned On.
I tried NVRAM reset also but no luck, Any help on this would be appreciable.
Thanks
Kamalarajan
Kamalarajan - Réponse
Have just received the A1281 replacement battery. However it does not charge. The magsafe light is on green but the battery is not charging. When I put in my old battery the magsafe goes to amber and it starts to charge. Any ideas?
domburton - Réponse
I just bought a new battery to replace A1281, and I have the same issue as you : the battery is not charging, power charger light is green.
I've tried to reset SMC, but it didn't solve anything.
Rodac -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 36
30 derniers jours : 170
Total : 84,648
