Aller au contenu principal
Remplacement de l'ensemble connecteur de charge Lightning de l'iPhone 11
Ce dont vous avez besoin
Instructions vidéo
Pour remonter votre appareil, suivez les instructions ci-dessus en sens inverse.
40 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Arty
Membre depuis le 10/27/19
24 585 Réputation
92 tutoriels rédigés
14 commentaires
I would rather have a picture and written step by step, he doesn’t say some parts what is called
Dulce Vidal - Réponse
Me too. I would appreciate knowing the size and type of all screws and standoffs and where they go.
I most likely mixed up a few of them and now the screen stays black.
Kim Mace -
First, DISCONNECT the battery before ANY connections, and the battery should be the last thing you re-connect. And you DO NOT need to remove the logic board.
Gregg Stanley - Réponse
Just completed this repair. Wow it’s tricky but as echoed above, I would try and disconnect battery first although design of the iPhone 11 makes it very difficult to do this. Also, definitely don’t remove logic board and you don’t have to remove the battery either. Removing battery possibly makes it very slightly easier but if you take your time it’s not necessary. Good luck
richarddillon - Réponse
IS not there a problem with at chip on the charging flex, that causes warnings and or re-boots I have been reading about somewhere?I mean, fitting it is easy enough, but APPPPle keeps annoying customers trying to stop them going to independent shops or doing repairs themselves!
JoeBlog - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 47
7 derniers jours : 410
30 derniers jours : 1,458
Total : 54,346
