Introduction
Pour changer la batterie, vous avez juste besoin de vos doigts!
Ce dont vous avez besoin
Avec vos doigts, écartez les deux clips de verrouillage de la batterie puis retirez la batterie de l'ordinateur.
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
132 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Claire Miesch nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
3 commentaires de tutoriel
Hello,
I have found a really important mistype, on this page.
I assume, that on the picture, those tools are not thumbs but the "Introduction" says so!!! Those are "finger" tools.
It can mislead persons like me also, with my 25 years old of highly educated professional tool user experience.
Please correct the tools down below.
With the thumb tool, i was unable unattach the battery from the case.
BR
Indeed, executing the detachment process of the battery using "thumbs" is a highly risky operation only to be performed by well-trained thumb specialists. The use of other "fingers" is much more common, as it might induce fairly less risk of severe injuries or death. Also, "Fingers" have a sweet little picture illustrating the right tool to use. I changed the guide accordingly.
Thank you so much gentleman for your help.
I appreciate the professional answer and the correction.
From now on i can sleep well at nights.
