Il est possible que cette traduction ne reflète pas les dernières mises à jour du tutoriel source. Aidez à mettre à jour la traduction ou bien consultez le tutoriel source.
Ce dont vous avez besoin
Appliquez de la chaleur, puis utilisez une ventouse pour soulever suffisamment le dos pour y placer un médiator en dessous.
Continuez à séparer l'adhésif sur les bords du téléphone, en réappliquant de la chaleur si nécessaire.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
4 autres ont terminé cette réparation.
Merci à ces traducteurs :
87%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
5 commentaires
I was surfing YouTube,I bumped into strange parts (lovethesite) he recommended ifixit.com, now I would like to replace my battery and volume buttons,on my Motorola e5plus,can that be done within fixit parts? how much? Shipping to USA 95401. Thank you.
I used your procedure on one Moto E5 Plus but did not discharge the battery to less than 1% and I punctured the bag and toasted my phone. PEOPLE NEED TO FULLY DISCHARGE THE BATTERY!!! I did this procedure on my second phone and was successful! The battery was impossible to get out without deforming the battery package. I pried and pried and pried and finally, pulled the battery from the adhesive.
There are lots of battery discharge apps that allow you to discharge rapidly. It is very difficult to not puncture the battery package. So be sure it is fully discharged before you do this procedure!
For best safety the phone battery needs to only be under 25%. The phone will say 0% and shut off, but the battery is not fully discharged. Completely discharging lithium ion batteries has the possibility to do serious damage to the chemistry, reducing its lifespan or capacity, or causing it to refuse to charge again.
I've edited the guide to mention this as well, but isopropyl alcohol (ideally high percentage) will soften most phone adhesive, making it significantly easier to remove.
Patrick -
The instructions say apply heat, but the heat gun has two settings. Which setting is best to use, and how far away from the surface, and for how long at a time?
Use low setting and heat until it's warm. You should be able to touch it comfortably. If the adhesive is still being difficult, alternate between heat and trying to remove
Patrick -
