Introduction
Avec ce tutoriel remplacez la batterie de votre Wii U GamePad.
Outils
Pièces
Le GamePad tourné vers le bas, dévissez les deux vis cruciformes Phillips #00 fixées au cache de la batterie.
Soulevez et retirez le cache de la batterie.
Pour remonter votre appareil, suivez les étapes dans l'ordre inverse.
11 autre(s) ont terminé cette réparation.
Merci à ces traducteurs :
100%
Claire Rapp nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
7 commentaires
There's no reason you can't but without the temp sensor you must be cautions if your battery does over heat because it can lead to damages on the touchscreen as well.
Why does Nintendo mention a size #0 screwdriver while iFixit says #00?
proof: http://en-americas-support.nintendo.com/...
"•Use a crosshead style, size #0 screwdriver to avoid damage to the screw or threads"
"2.Loosen the battery cover screws with a crosshead style, size #0 screwdriver."
/a confused person
The size #00 is just a little smaller than the #0. When we wrote these guides, we used whatever worked for us. Either should work, but generally you should use the largest that will work to avoid stripping the screw.
Kim Arre -
