Aller au contenu principal
Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009
Ce dont vous avez besoin
  1. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009, Trappe d'accès: étape 1, image 1 de 2 Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009, Trappe d'accès: étape 1, image 2 de 2
    • Boîtier fermé, placez l'Unibody à l'envers sur une surface plane.
    • Appuyez sur le côté rainuré du loquet de déverrouillage de la trappe d'accès de manière à saisir l'extrémité libre du loquet. Soulevez le loquet de déverrouillage à la verticale.
    The A1286 has no Access Door.!!
    I actually can see no sign of the battery!...
    aguib - Réponse
    Citation de aguib :
    I assume you have the newer model, with the built-in battery. It's still removable with tools, but these are the wrong instructions for that model.
    lgc90 - Réponse
    when will there be a guide for the other unibody macbook pro. that does not have an access door?
    irishking - Réponse
    Is there a manual to show, how disasembly the display, i mean, after step 5, to check the display between lcd and aluminiun back case?
    Max
    Max - Réponse
    On other guides you state the height of the HD that can be supported, e.g. Remplacement du disque dur du MacBook Pro 15" Core 2 Duo modèle A1211 , I have read ( but have not confirmed ) that the uni-body MacBook Pro can be fitted with the 750GB and 1TB 12mm drive from Western Digital.
    Can you confirm this?
    Many thanks in advance.
    ahothabeth - Réponse
    Citation de SHerwood Ball :
    My display and aluminum casing has separated.
    I don't know if it just snaps back together or does it need to be glued.
    I dropped mine on the carpeted stairs and the display still works.
    I'm hoping I can just snap it back together and that no plastic pieces or teeth of the snapping
    portion have been broken........
    SHerwood Ball - Réponse
    When you say "left fan" is this "left when looking at the logic board after turning the computer over and looking it up opening it up" or "left when sitting at the computer keyboard and typing on it"?
    thvv - Réponse
    We always use left and right in reference to the computer when you're using it.
    Andrew Optimus Goldheart -
    Directions were great and the worn dc in board was replaced. The hardest part of the procedure is disconnecting the data display cable. A better description of step 21 is to slide the connector parallel to the circuit board towards the outside corner. Reconnecting correctly took several tries.
    I used the tip of the spudger to nudge the corners a little at a time to seat the connector.
    The ribbon connector for the keyboard has to be inserted all the way before seating the retaining cap. It took me three tries . First try power button did not work second try numbers keys did not work.
    Thanks for the directions ...could not have done it with out them!!!
    landryd - Réponse
    Hola. Poseo un MacBook Pro Late 2008 y debo cambiarle las cornetas. Me sirve unas cornetas de un MBP Late 2011?
    jegonzalez80 - Réponse
    Please read the instructions about removing the bluetooth cable - you CAN work around it, and NOT take off the plug.
    kenneth krabat - Réponse
  2. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 2, image 1 de 1
    • La trappe d'accès est à présent suffisamment relevée pour la basculer et la retirer de l'Unibody.
  3. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009, Batterie: étape 3, image 1 de 1
    • Assurez-vous que la languette de la trappe d'accès est bien à la verticale avant de commencer.
    • Tirez sur la languette et retirez la batterie de votre MacBook.
    • Si la languette n'est pas bien positionnée, elle empêchera la batterie de sortir.
    Do I need to wait for the battery to charge completely before using the computer (while plugged in)?
    Kaila Potts - Réponse
    No. You do not need to charge it completely before removing it.
    Titus (#1579) - Réponse
  4. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009, Boîtier inférieur: étape 4, image 1 de 1
    • Retirez les huit vis suivantes par lesquelles le boîtier inférieur est fixé au châssis :
    • Une vis Phillips 5,4 mm.
    • Trois vis Phillips 14 mm.
    • Quatre vis Phillips 3,5 mm.
    Hi, My name is Jess I need help asap I accidentally dropped my macbook Pro and i cant find the silver screw for the top left back side, Does any one know if I can replace it with an eye glass screw?? If you can help at all Please e-mail me at Chambliss_jess@yahoo.com thx please help me my bf is going off... ;(
    Jess - Réponse
    The fixit PH00 is the wrong screw driver for this entire job. It did not fit in the screws, it was too pointy and caused screws to be rounded off.
    mattrittgers - Réponse
  5. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 5, image 1 de 1
    • En vous servant des deux mains, soulevez le boîtier inférieur et retirez-le du boîtier supérieur.
    About midway along each edge is a snap. To release each snap, gently slide the flat edge of a Spudger under the lower case, then lift the lower case away.
    jonathansturges - Réponse
  6. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009, Paroi interne: étape 6, image 1 de 1
    • Dévissez les 5 vis suivantes, fixant la paroi interne au boîtier supérieur :
    • Trois vis cruciformes de 10,5 mm.
    • Deux vis cruciformes de 3,7 mm.
  7. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 7, image 1 de 1
    • Ôtez la paroi interne du boîtier supérieur.
  8. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009, Carte mère: étape 8, image 1 de 1
    • Retirez les six vis suivantes fixant le ventilateur droit et le ventilateur gauche à la carte mère :
    • Quatre vis cruciformes de 3,5 mm.
    • Deux vis cruciformes de 3,2 mm.
    Pry under the side where the wires connect.
    colleenthompson - Réponse
    I think this the screw dimensions may be reversed. My late 2008 Unibody had four 3.2mm and two 3.5mm.
    Christian Lallo - Réponse
  9. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 9, image 1 de 3 Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 9, image 2 de 3 Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 9, image 3 de 3
    • Avec la pointe d'une spatule (spudger), soulevez le connecteur du ventilateur droit vers le haut pour le débrancher de sa prise sur la carte mère.
    • Veillez à seulement faire levier sur le connecteur lui-même et non sur la prise ou vous risquez d'endommager le dispositif.
    • Il est utile de faire pivoter la spatule en dessous des câbles du ventilateur pour débrancher le connecteur.
    • Retirez le ventilateur droit du boîtier.
    Be really gentle and patient with this connector, I popped the socket right off of the logic board (thankfully the already broken one that I was replacing). It actually shouldn't take much force, and just gently work on it until it comes out.
    Mark Middleton - Réponse
  10. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 10, image 1 de 3 Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 10, image 2 de 3 Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 10, image 3 de 3
    • Avec la pointe d'une spatule (spudger), soulevez le connecteur du ventilateur gauche vers le haut pour le débrancher de sa prise sur la carte mère.
    • Retirez le ventilateur gauche du boîtier.
    I unfortunately broke the fan receptacle connector (2 pin) on the board. How do I order a new connector and how do I put it on?
    Kevin Hamby - Réponse
  11. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 11, image 1 de 1
    • Retirez toute bande adhésive du connecteur de la nappe de la caméra.
    • Déconnectez la nappe de la caméra en retirant l'extrémité mâle de sa prise. Tirez parallèlement à la carte mère, ne soulevez pas le connecteur vers le haut.
    There's a little shiny piece of plastic holding this item in place to keep it from sliding out of it's slot. It's glued on and if you don't take it off first, you'll likely bend the connector so that it won't work anymore. Ruined a motherboard because this step was missing.
    maccentric - Réponse
    What this guy said - REMOVE the shiny plastic block first. Also the "straight away" means sliding outwards TOWARDS THE OPTICAL BAY - *NOT* upwards.
    Damien - Réponse
    I broke the connector for the subwoofer. Do I have to replace the logic board?
    jbp0471 - Réponse
    It is not necessary to disconnect the camera cable to remove/replace the left speaker. You can leave the cable connected to save you from damaging it.
    Daniel Fišer - Réponse
  12. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 12, image 1 de 1
    • Avec une spatule (spudger), faites délicatement levier vers le haut pour retirer le connecteur du lecteur optique de sa prise sur la carte mère.
  13. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 13, image 1 de 1
    • Si nécessaire, retirez l'amortisseur en mousse recouvrant le connecteur du subwoofer.
    • Avec l'extrémité plate d'une spatule (spudger), faites levier vers le haut pour retirer le connecteur du subwoofer de sa prise sur la carte mère.
    • Faites très attention. Cette connexion est fragile et la prise se détache facilement de la carte mère.
    I Broke the subwoofer socket on the logic board. Can I use without subwoofer, or do I now have to replace the logic board?
    jbp0471 - Réponse
    Sorry to hear this. Yes, you can use the machine without the subwoofer. To be safe, cover the subwoofer plug with some electrical tape so that it can't cause a short circuit somewhere.
    Marty Swartz -
  14. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 14, image 1 de 1
    • Avec l'extrémité plate d'une spatule, faites levier vers le haut pour retirer le connecteur argenté de la nappe du disque dur de sa prise sur la carte mère.
  15. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 15, image 1 de 1
    • Avec une spatule, faites levier vers le haut pour retirer le connecteur du pavé tactile de sa prise sur la carte mère.
  16. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 16, image 1 de 2 Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 16, image 2 de 2
    • Avec la pointe d'une spatule (spudger), ouvrez le clapet de retenue du câble IR/veille/LED.
    • Tirez le câble IR/veille/LED tout droit hors de sa prise.
    Hi, thanks for this tutorial: it solved my problem.
    But unfortunately I have broken the IR/sleep LED ribbon cable socket on motherboard (cable is ok, socket crumbled): computer works fine but now it doesn't go on standby anymore. Is there a way to fix the cable on motherboard (for example with Kapton tape) or is there a software to manage computer standby?
    Thanks in advance for your help.
    Mary
    mary - Réponse
    Hi, thanks for this tutorial, it is really helpful. Unfortunately I cannot push the ribbon cable into the socket. The space is really limited, the cable is hard, and the socket seems to be too narrow. Is there any tool to push this kind of cable in a short space? Very fine plastic tweezers could work? Even without this cable the Mac can work, so I leave it before I break it.
    Hideyuki
    Hideyuki Tatsuno - Réponse
  17. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 17, image 1 de 1
    • Avec une spatule, faites levier vers le haut pour retirer le connecteur du voyant lumineux de la batterie de sa prise sur la carte mère.
    • Faites levier sous les câbles pour éviter que la prise ne se détache de la carte mère.
  18. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 18, image 1 de 2 Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 18, image 2 de 2
    • Avec la pointe d'une spatule, ouvrez le clapet de retenue de la nappe du clavier.
    • Tirez la nappe clavier tout droit hors de sa prise.
    • Lors du remontage, veillez à réinsérer complètement la nappe du clavier dans la prise ZIF.
    I ran into trouble when re-installing the keyboard cable. I got everything put back together, plugged it in, and pressed Power... and nothing happened. I took everything apart again, reseated the heat sink and everything, put it back together... and the Power button didn't respond.
    The MagSafe light came on, and the battery charge lights came on. But it wouldn't power up.
    Finally I figured out that the keyboard cable is really tricky to get in correctly. If you can slide it out with the retaining clip locked (applying very little pressure), then the cable isn't actually in correctly. I had to really fiddle with it, and maybe slide it in one side first, to see that it actually needed to slide in another 1/8th inch or so beyond what felt like "in" the first few times I did it.
    Once I'd secured that cable, my MacBook turned on again without a problem. So far, after just replacing the Thermal Paste (I didn't actually install a new heat sink), the computer is running 20°F cooler than it has in years. Thanks!
    simolinic - Réponse
    I think I broke the keyboard ribbon cable, now I have to replace the keyboard.....
    Francesco Zhu -
    I agree. The instructions should place emphasis on seeing how deep this ribbon is. Most ribbons are pretty easy to slot back in. This one is not (maybe because of the colour). The IR/sleep is a b... too!
    Jerome - Réponse
    Hi Jerome. Thank you for your feedback. I agree with you and simolinic. There should be a reminder bullet that warns people about the depth of the ribbon cable. Thanks for adding that. Much appreciated.
    Walter Galan -
    Thank you simonlinic, for pointing this out. I was so disapppointed when the MacBook Pro wouldn't start up. I reopened the MacBook and was able to insert the keyboard ribbon cable quite a bit more by pushing agains the top of the cable while inserting it. I tired starting up after that and it still wouldn't start. I took a 15 minute break and then it started up perfectly! I'm grateful to you all!
    Sy Bram - Réponse
    Here is the best way to reinsert this cable: MacBook unibody keyboard ribbon cable won't go in Putting a piece of tape on the connector (creating a pull-tab) and pulling it in works great.
    Cooper - Réponse
  19. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 19, image 1 de 2 Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 19, image 2 de 2
    • Avec la pointe d'une spatule, ouvrez le clapet de retenue du câble du lecteur de carte mémoire (Express Card).
    • Tirez le câble du lecteur de carte mémoire tout droit hors de sa prise.
  20. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 20, image 1 de 1
    • Avec une spatule, faites levier vers le haut pour retirer le connecteur de la nappe du microphone de sa prise sur la carte mère.
    • Faites levier sous les câbles pour éviter que la prise elle-même ne se détache de la carte mère.
    I don't believe this step is actually necessary, the cable is attached on the other side of the logic board and comes along with it, so it just isn't really necessary to disconnect (although it's not hard either).
    Trevor Kemp - Réponse
  21. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 21, image 1 de 2 Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 21, image 2 de 2
    • Saisissez la languette en plastique fixée au dispositif de verrouillage du câble de données de l'écran et faites-la pivoter vers le côté DC-In (prise d'alimentation) de l'ordinateur.
    • Tirez le câble de données de l'écran tout droit hors de sa prise.
    • Quand vous déconnectez le câble de données de l'écran, n'appuyez pas sur la languette noire fixée au dispositif de verrouillage du câble. Nous recommandons de remuer le câble pendant que vous le tendez afin de faire sortir peu à peu le connecteur de sa prise.
    • Lors du remontage, assurez-vous que le câble de données de l'écran est placé correctement dans sa prise. Si ce n'est pas le cas, l'affichage de l'écran sera partiel ou ne fonctionnera pas du tout.
  22. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 22, image 1 de 2 Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 22, image 2 de 2
    • Repérez la nappe du rétro-éclairage du clavier (près de l'emplacement du ventilateur gauche).
    • Avec la pointe d'une spatule (spudger), ouvrez le clapet de retenue de la nappe du rétro-éclairage du clavier.
    • Tirez la nappe du rétro-éclairage de l'écran tout droit hors de sa prise.
  23. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 23, image 1 de 1
    • Dévissez les sept vis cruciformes de 3,2 mm, fixant la carte mère au boîtier supérieur.
    • Ne retirez pas encore la carte mère ! Il faut d'abord déconnecter les connecteurs fixés sous la carte mère.
    On reassembly, check carefully that none of the fiddly little cables are trapped under the logic board. I had to back up and liberate the subwoofer connector. It takes some careful jiggling to get the sockets seated in the port holes.
    The two screws closest to the optical drive have smaller heads. (May not be critical.)
    Marty Swartz - Réponse
  24. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 24, image 1 de 1
    • Dévissez les deux cis cruciformes de 7 mm fixant la carte de raccordement MagSafe (DC-In Board) au boîtier supérieur.
    • Remarque : Cette étape n'est pas absolument nécessaire mais ceci facilite la déconnexion du câble connecté à la carte DC-in.
  25. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 25, image 1 de 2 Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 25, image 2 de 2
    • Dévissez les deux vis cruciformes de 3,5 mm fixant le dispositif d'appui inférieur au boîtier supérieur.
    • Retirez ce dispositif d'appui du boîtier supérieur.
    • Certains MacBook Pro Unibody n'ont pas de dispositif d'appui et ne nécessitent donc pas cette étape.
    My clip is oriented 180 degrees (flipped) from this picture.
    The bottom case clip is screwed to a black plastic bracket that's glued onto the upper case. My replacement upper case did not come with this bracket. I had to carefully pry it off the old upper case, taking care not to break it, and glue it to the new upper case before replacing the logic board.
    I have a 2.66ghz 15inch Unibody Macbook Pro (A1286) and this step was not necessary.
    Andrew Magpoc - Réponse
    Citation de Andrew Mostajo :
    I have a 2.66ghz 15inch Unibody Macbook Pro (A1286) and this step (24) was not necessary.
    Apropos to the last tip in this step, the replacement unibody I purchased omitted the receiving end of this clip, but it was in my original. As it only captures (but does not secure) a small metal tab on the bottom cover, I skipped transferring it.
    Brett Deriso - Réponse
    Agree with @colleenthompson - mine was also rotated 180 degrees from what is shown, which also matches the other side of the computer.
  26. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 26, image 1 de 2 Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 26, image 2 de 2
    • Soulevez soigneusement l'ensemble carte mère en commençant par le côté gauche et retirez-le du boîtier supérieur en faisant attention du côté des ports qui pourraient y rester accrochés au cours de l'étape.
    • Ne retirez pas encore complètement la carte mère !
    • Assurez-vous que la carte mère n'a plus aucune connexion avec le boîtier supérieur (sauf le connecteur de la batterie) avant de procéder.
    • Lors du remontage, assurez-vous qu'aucun des connecteurs et câbles ne se trouve sous la carte mère. Quelques unes des nappes sont très fines et fragiles.
  27. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 27, image 1 de 2 Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 27, image 2 de 2
    • Soulevez la carte mère de façon à pouvoir saisir le connecteur de la batterie et tirez-le tout droit hors de sa prise sur la carte mère.
    • Retirez l'ensemble carte mère du boîtier supérieur.
    I didn't have to do this step, I just leaned the logic board up and changed the DC board.
    dmeyer302 - Réponse
    Its better to carefuly “flip” the board towards battery compartment and then take the connector out. The way, how it is written here, its badly accessible with fingers and with tweezers and the connector has plastic point which clicks into hole in the middle of connector. So its better to carefully flip the board upside out and then take it carefully out.
    Petr Sourek - Réponse
  28. Remplacement de la carte de raccordement MagSafe des MacBook Pro 15" Unibody fin 2008 et début 2009, Carte de raccordement MagSafe (DC-In Board): étape 28, image 1 de 1
    • Déconnectez le connecteur de la carte de raccordement MagSafe (DC-In) de la carte mère en le tirant tout droit hors de sa prise sur la carte mère.
    Awesome guide! This was my first time inside any laptop let alone a mac. I have a whole new appreciation for the hardware engineers over there. While it was apart I took the LCD out as well to fix some things that have been bugging me. I used another one of your guides for that. Thank you so much for the quality pictures and instructions. Start to finish for all of it was about 3 hours.
    Thanks again!!!
    Daniel - Réponse
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
35 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Claire Miesch nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
2 commentaires
Thanks for your answer, lovely clear information. Just one thing, is it at all possible the problem arises from the cable end rather than the MagSafe DC? I ask this with great hope as it would be a lot easier to replace.
lizzie - Réponse
Fantastic! Perfect instructions!!
Adrian Dunne - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 40
Total : 29,205
