Aller au contenu principal
Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010
Ce dont vous avez besoin
  1. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010, Retirer les vis du boîtier inférieur: étape 1, image 1 de 1
    • Retirez les 10 vis suivantes par lesquelles est fixé le boîtier inférieur du MacBook Pro 13" Unibody :
    • Sept vis Phillips 3 mm.
    • Trois vis Phillips 13,5 mm.
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - Réponse
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - Réponse
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - Réponse
    I use a magnetic mat and place the screws in order on that :)
    Cary B - Réponse
  2. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010, Soulever le boîtier inférieur: étape 2, image 1 de 1
    • Soulevez légèrement le boîtier inférieur et poussez-le vers l'arrière de l'ordinateur afin de désengager les pattes de fixation.
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - Réponse
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - Réponse
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010, Batterie: étape 3, image 1 de 1
    • À titre de précaution, nous vous conseillons de débrancher le connecteur de la batterie de la carte mère afin d'éviter les décharges électriques.
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur de la batterie pour le débrancher de la prise sur la carte mère.
    Citation de gansodesoya :
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - Réponse
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - Réponse
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - Réponse
  4. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010, Ventilateur: étape 4, image 1 de 3 Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010, Ventilateur: étape 4, image 2 de 3 Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010, Ventilateur: étape 4, image 3 de 3
    • Avec une spatule (spudger), soulevez le connecteur du ventilateur pour le débrancher de sa prise sur la carte mère.
    • Il est utile de faire pivoter la spatule en dessous des câbles du ventilateur pour débrancher le connecteur.
    • La prise et le connecteur du ventilateur sont montrés sur la deuxième et troisième photo. Veillez à ne pas détacher la prise en plastique du ventilateur de la carte mère lors du retrait du connecteur de sa prise. La configuration de la carte mère de votre machine peut différer de celle de la deuxième photo mais la prise du ventilateur est la même.
    The image is very misleading. This is why many people are breaking their connectors. Please correct this and make it VERY clear that one has to put the spudger straight behind the cables, NOT behind the connector, as shown in the pic.
    Giunia - Réponse
    Thankfully there is a helpful guide in the comments on this post for fixing the socket in the likely event that you snap the sucker clean off like I did:
    I popped off the fan connection from the logic board...Fix?
    agoodcourage - Réponse
    As Giunia said I too just broke the connector only because the photo shows to slide a spudger between the connector socket and the motherboard. I am now out of my only computer. This is VERY frustrating.
    Nha1234 - Réponse
    Broke it as well the picture is very misleading.
    Christian Flores - Réponse
    Local mobile repair shop soldered it back for me.. but it cost me twice as much as fan I ordered from china. They told me to use two tools in the future.. one to keep the edge down and other to gauge gently from under the cables...
    Bade -
  5. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 5, image 1 de 1
    • Retirez les trois vis suivantes :
    • Une vis Torx T6 de 7 mm
    • Deux vis Torx T6 de 5,4 mm
  6. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 6, image 1 de 1
    • Ôtez le ventilateur du boîtier supérieur.
  7. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010, Carte mère: étape 7, image 1 de 3 Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010, Carte mère: étape 7, image 2 de 3 Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010, Carte mère: étape 7, image 3 de 3
    • Saisissez la languette en plastique fixée au dispositif de verrouillage du câble de données de l'écran et pivotez-la vers le côté DC-In (prise d'alimentation) de l'ordinateur.
    • Tirez le connecteur du câble de données de l'écran tout droit hors de sa prise.
    On my system the pad on top of the connector was shifted making the bracket difficult to rotate into the up position. The bracket looks like a handle so my first instinct was to pull it straight up. Big mistake. I ended up popping the brass guard off the connector on the logic board. The instructions could benefit from an arrow indicating the direction to pull and rotation of the bracket.
    highnoontoday - Réponse
  8. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 8, image 1 de 2 Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 8, image 2 de 2
    • Dévissez les deux vis suivantes, attachant la fixation du câble de données de l'écran au boîtier supérieur :
    • Une vis cruciforme de 8,6 mm
    • Une vis cruciforme de 5,6 mm
    • Ôtez la fixation du câble de données de l'écran du boîtier supérieur.
  9. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 9, image 1 de 1
    • Avec l'extrémité plate d'une spatule, faites levier sur le connecteur du subwoofer et du haut-parleur droite pour le débrancher de la carte mère.
    Push it straight down. It should snap in.
    BobG - Réponse
    The first time i tried this on a MBP 13 I broke the connector form the board. It should be noted that you have to be very careful in this step, as the plug fits very tightly and you can easily use too much force to tear the connector from the board. Use a second spudger to hold down the connector at its border and try very gently using a second spudger to move the plug out of the connector upwards.
    Joachim Kathmann - Réponse
  10. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 10, image 1 de 1
    • Tirez le connecteur de la nappe de la caméra vers le lecteur optique pour le déconnecter de la carte mère.
    • Cette prise métallique se tord facilement. Veillez à aligner le connecteur et sa prise sur la carte mère avant de les réassembler.
    As mentioned, the socket can be easily damaged when re-inserting it. I didn't care enough and one pin was damaged. Wifi was not detected.
    Hopefully the pin was not broken (only bent). Putting it back in its correct position, the wifi re-appeared.
    Arnaud ROSAY - Réponse
  11. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 11, image 1 de 3 Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 11, image 2 de 3 Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 11, image 3 de 3
    • Avec l'extrémité plate d'une spatule, faites levier sur les connecteurs des nappes du lecteur optique, du disque dur et du pavé tactile pour les débrancher de la carte mère.
  12. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 12, image 1 de 3 Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 12, image 2 de 3 Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 12, image 3 de 3
    • Avec votre ongle ou la pointe d'une spatule, ouvrez le clapet de retenue de la prise ZIF de la nappe clavier.
    • Avec votre spatule, faites glisser la nappe du clavier hors de sa prise.
    Sometimes spulger is not the best tool to slide the cable out. If it is difficult to slide, try two toothpicks to pull the cable from two sides simultaneosly.
    Leo Nikitin - Réponse
    Toothpicks did the trick, thanks
    Gábor SEBESTYÉN -
    As Mateo said, replacing the zif cable is NOT easy, and in this case, will leave you with a computer that won't power on- this cable connects the power button. I learned a trick somewhere for dealing with these cables- put a piece of good sticky tape on the cable, and use it to pull it back into the connector. Works every time.
    stevesontheroad - Réponse
    Yeah! The tape trick worked for me. Thanks!
    Ted Bishop -
    Thank you Steve, it’s works perfectly.
    never_forever18 -
  13. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 13, image 1 de 1
    • Décollez le petit morceau de bande adhésive noire sur la prise de la nappe du rétro-éclairage du clavier.
    Be very careful while taking this black tape off. I accidentally broke the chip off the motherboard and so my keyboard is not backlit any more.
    Asim Akath - Réponse
  14. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 14, image 1 de 3 Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 14, image 2 de 3 Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 14, image 3 de 3
    • Avec la pointe d'une spatule, ouvrez le clapet de retenue de la prise ZIF de la nappe du rétro-éclairage du clavier.
    • Avec votre spatule, faites glisser la nappe du rétro-éclairage du clavier hors de sa prise.
    Be especially careful as my hole socket detached from the board. It would have helped to vertically press the socket to the board with the tip of a spudger. Thus partially blocking the strap, you can first peel the free end, then change position and peel the rest. Slide the ribbon cable perfectly horizontally.
    Rainer - Réponse
    I had the same issue of trying to get the ZIF cable back in but found that if I used a piece of scotch tape, it worked. I followed this guide. MacBook unibody keyboard ribbon cable won't go in
    spearson - Réponse
    A reassembly trick that works for me is to use some 3/4" blue painters tape to stick to the very back (lower end) of the ribbon cable so I can pull it up and back before locking the cam. Trying to get a good grip without cutting, or crimping the ribbon means no tweezers or pliers can be used.
    originalmachead - Réponse
  15. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 15, image 1 de 1
    • Avec l'extrémité plate d'une spatule, faites levier sur le connecteur de la nappe du voyant de la batterie pour le débrancher de la carte mère.
    If you’re swapping top cases, you might need to remove the battery indicator from the case and swap it to the replacement top case. It attaches with three very tiny Phillips screws. I wasn’t aware that my replacement top case didn’t have this part and got confused when reversing the steps to reassemble and I didn’t have this connector. I had to take the battery back out in order to swap the indicator over.
    Mark Barnes - Réponse
    Interesting this guide doesn’t have you disconnect the battery after step 2 then shows it unplugged already in step 14.
    plink53 - Réponse
    I would recommend revision to this guide to put battery disconnection as the first step after opening the bottom case. First rule of logic/mother boards: don’t work on or around if power is applied.
    dsfeehan - Réponse
  16. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 16, image 1 de 1
    • Avec la pointe d'une spatule, décollez le microphone de la bande adhésive le fixant au boîtier supérieur.
    on the Australian/Asia version speaker cable is located underneath the logic board.
    linuxuser101 - Réponse
    Norwegian/European versjon too. Recommend using a pincer to lift it up.
    Note you’re not supposed to only remove the rubber, in fact that should stay on
    eisa01 - Réponse
  17. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 17, image 1 de 1
    • Dévissez les vis suivantes :
    • Deux vis Torx T6 de 7 mm sur la carte de raccordement MagSafe (DC-In)
    • Cinq vis Torx T6 de 3,3 mm
    • Deux vis Torx T6 de 4 mm
  18. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 18, image 1 de 2 Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 18, image 2 de 2
    • Il n'est pas absolument nécessaire d'enlever la batterie avant de retirer la carte mère mais cela rend cette étape plus facile et plus sûre. Si vous laissez la batterie à l'intérieur, soyez particulièrement attentif à ne pas heurter la carte mère au boîtier de la batterie à côté du code barres.
    • Dévissez les vis tri-wing suivantes, fixant la batterie au boîtier supérieur :
    • Une vis tri-wing de 5,5 mm
    • Une vis tri-wing de 13,5 mm
    • Ôtez la batterie du boîtier supérieur.
  19. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 19, image 1 de 2 Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010: étape 19, image 2 de 2
    • Saisissez la carte mère par le côté gauche et soulevez-la jusqu'à ce que les ports s'écartent du bord du boîtier supérieur.
    • Éloignez la carte mère du bord du boîtier supérieur et retirez-la en évitant que la carte de raccordement MagSafe (DC-In) ne reste accrochée.
    Be careful while taking the board out, as the heatsink usually is caught by the optic drive.
    mid 2012: Careful of the left speaker (on your right because unit is upside down). Gently remove with spudger tool before removing logic board and when reinstalling press firmly back into place with spudger. Install speaker after putting logic board in place but before installing screws.
    JASON CULP - Réponse
    Step 18 is out of order. Steps following this show it still installed, which is confusing.
    plink53 - Réponse
  20. Remplacement de la carte de raccordement MagSafe du MacBook Pro 13" Unibody mi-2010, Carte de raccordement MagSafe (DC-In): étape 20, image 1 de 1
    • Déconnectez la carte de raccordement MagSafe (DC-In) en retirant son connecteur de la prise sur la carte mère.
Pour remonter votre ordinateur, suivez les mêmes instructions dans l'ordre inverse.
82 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Claire Miesch nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
4 commentaires
The Tri-wing Y1screwdriver suggested for this procedure is too big for the removal of the battery screws. I completed replacing the DC in board without removing the battery.
rkterao - Réponse
I have just tested several of those drivers from our shelf in 3 different MacBooks we have here with tri-wing type screws, and they are all a perfect fit. I have sent you an email to try and find out why your driver did not fit, you may have a mid 2009 model with pentalobular screws instead?
Eric Essen -
Thanks! Guide was wonderful! I wish there had been a bit more information about the proper routing of the dc-in cable as the first time I put it back together I accidentally routed the cable on the outside of the mother board riser which made it impossible to seat the display cable hold down clamp properly. I had to re-remove the main board in order to get the dc-in cable on the other side of the riser. Not a biggie, but a note on that step would be helpful. Thanks again!!
joyandrob - Réponse
So I switched it out, but in the process ripped the battery indicator cable connector, and now the wifi doesn’t work either… it’s super slow to start up. Any suggestions for fixes?
KitandJake Book - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 73
Total : 67,079
