Aller au contenu principal
Remplacement de la vitre d'écran du MacBook Pro 15" Unibody
Ce dont vous avez besoin
  1. Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Préparer l'espace de travail: étape 1, image 1 de 1
    • Installez-vous sur un espace propre et rassemblez tout le matériel nécessaire. Vous aurez besoin de votre MacBook Pro, d'un nouvel écran, d'un sèche cheveux, d'un chiffon de nettoyage d'écran et d'une ventouse.
  2. Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Chauffez les bords de l'écran: étape 2, image 1 de 2 Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Chauffez les bords de l'écran: étape 2, image 2 de 2
    • Utilisez un sèche-cheveux pour chauffer l'adhésif autour des bord de l'écran que vous allez retirer.
    It would be very helpful if someone gave us a hint as to how hot to get the glass before the adhesive releases fairly easily. I didn't get it quite hot enough, I think, as it was a bear to get it started to release. My glass was pretty badly smashed around the iSight camera, and that part was a b*tch to get off. I was worried about damaging the LCD or some other component in the lid by getting it too hot.
    Can anyone give us some further tips on this point?
    jiclark - Réponse
    I agree with jiclark. How hot should you get this? This instruction set is poorly written. I heated mine up beyond being able to touch the housing and the adhesive would not release. It melted the rubber surround though… THANKS ifitit.com You just BROKE IT!
    Nunov Urbiznes - Réponse
    You have to read the tutorial before doing it. If it doesn't fit with your problem, you are the only person responsible.
    Kevin Bonvin -
    Nunov is correct, this tutorial makes this repair look a lot simpler than it really is. A hair dryer is not the correct tool, as Nunov stated, it will melt the rubber before the glue releases the screen. Check out this video to see how difficult this repair can actually be. You’ll have to ignore the language and the bird (really annoying). https://www.youtube.com/watch?v=_cbvZ2id...
    Ransom Valley - Réponse
    I just melted the rubber inside the Mac Screen And broke my LCD. My glass, ironically, is still very intact.
    I cannot in good faith recommend that anyone try the steps.
    I feel like this guide was written so that they could say that they've made a guide.
    Kevin McCartney - Réponse
    I am here to help. First, this is advanced procedure and requires very steady hands and patience - most people don’t have that and will make a small error that ruins the entire job. I’ve installed cat stereos and worked on computer stuff for many years. Okay, so let’s talk tools. You will need a hair dryer. It is best to have one with a blower attachment. This funnels the hot air into a long horizontal funnel that is about 4 inches wide and 1 inch tall. Perfect for heating a specific small area. The next tool you’ll need is a set of car stereo installation wedges. These are plastic wedges designed for jobs just like this one. The plastic does not damage or scratch and is sharp enough to lift and cut through adhesive (I had to use a Dremel sander to make mine sharper because it was used for other projects). Now, the top is extremely difficult. I recommend starting on the top left corner. Your goal is to get the corner lifter and wedge under……..(continued)
    Dustin Curtis - Réponse
    (under)…the glass AND the glue ribbon. If this is achieved, begin going down the left side from top to bottom. Go across the bottom. I went all the way across but that was is easy to damage the lcd by touching it with the plastic wedge. Be mindful of the wedge and lcd. Work is small areas of 4 inches long when heating and lifting. The top area around the camera is a challenge. There is a metal plate covering the camera and mic. If you succeed in keeping the glass mostly whole and intact, this will help. Mine was shattered to !&&* around the camera - very challenging. As I worked I used a handheld vacuum with a brush attachment. The glass shards will scratch the screen underneath. Be careful! Use a static free cloth to get excess fish and glass off before the reinstall. Hope this helps.
    Dustin Curtis -
  3. Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Utilisation d'une ventouse pour retirer l'écran: étape 3, image 1 de 3 Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Utilisation d'une ventouse pour retirer l'écran: étape 3, image 2 de 3 Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Utilisation d'une ventouse pour retirer l'écran: étape 3, image 3 de 3
    • Attachez la ventouse (fournie dans le kit de réparation iFixit) au coin d'un angle de votre écran en appuyant doucement dessus jusqu'à ce que ce soit scellé. Ensuite, soulevez l'écran en tirant sur l'anneau de la ventouse.
    Another GARBAGE step. If you are having to replace a broken screen how on earth will a suction cup work. The screen is cracked so it can’t make suction. Way to go ifixit.com replacing a good screen with another good screen to show how to do something. You are a joke!
    Omg, changing a glass is not that easy. This tutorial is mage by a member of the community, it's not an official iFixit one. So please, be smart and read more about your problem next time.
    MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement
    Kevin Bonvin -
    The only way I was able to get through this step was to take a syringe And inject acetone In between been the now obliterated rubber gasket.
    Absolute cobblers - anyone who has done this repair knows it doesn’t come out that easy!!!!
    Chris Hadley - Réponse
  4. Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Préparation: étape 4, image 1 de 2 Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Préparation: étape 4, image 2 de 2
    • Utilisez un chiffon de nettoyage d'écran pour enlever toute trace sur la surface de l'écran.
    • Utilisez le chiffon de nettoyage d'écran pour enlever toute impureté sur l'intérieur de la nouvelle vitre.
  5. Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Préparez l'adhésif de l'écran: étape 5, image 1 de 2 Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Préparez l'adhésif de l'écran: étape 5, image 2 de 2
    • Enlevez les bandes qui couvrent la partie adhésive du nouvel écran.
    • Chauffez uniformément les nouvelles bandes adhésives en utilisant le sèche-cheveux.
  6. Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Posez le nouvel écran: étape 6, image 1 de 2 Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Posez le nouvel écran: étape 6, image 2 de 2
    • Placez le nouvel écran dans la même position qu'indiqué sur l'image. Veillez à ce que le nouvel écran soit proprement aligné avec les bords du MacBook Pro.
  7. Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Attachez le nouvel écran: étape 7, image 1 de 2 Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Attachez le nouvel écran: étape 7, image 2 de 2
    • Avec le chiffon de nettoyage d'écran, appuyez soigneusement sur les bords de l'écran pour sceller l'adhésif.
  8. Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Retirez la protection: étape 8, image 1 de 1
    • Décollez la protection du nouvel écran.
  9. Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Réchauffez l'adhésif: étape 9, image 1 de 3 Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Réchauffez l'adhésif: étape 9, image 2 de 3 Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Réchauffez l'adhésif: étape 9, image 3 de 3
    • Pour assurer le maintien de l'adhésif, réchauffez le encore une fois avec le sèche-cheveux.
  10. Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Finalisation: étape 10, image 1 de 1
    • Enfin, utilisez le chiffon de nettoyage d'écran pour appuyer encore une fois sur les bords de l'écran
  11. Remplacement de la vitre d'écran du MacBook Pro 15" Unibody, Vous l'avez fait !: étape 11, image 1 de 1
    • Profitez de votre MacBook Pro avec sa vitre flambant neuve !
    comment faire pour ajuster la can après le changement d’écran, quand on l’ouvre l’image est toute flou ?
    Sylvain Cyr - Réponse
Ce tutoriel inclut toute les instructions nécessaires au démontage et au replacement de l'écran d'un MacBook Pro.
41 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Akh1913
Membre depuis le 10/16/15
1 282 Réputation
1 tutoriel rédigé
Équipe
PIRL Gadget Garage Membre de l'équipe PIRL Gadget Garage
Community
9 membres
10 tutoriels rédigés
20 commentaires
How did you know the correct part number for your specific MacBook? Where did you source the glass?
frightanic.com - Réponse
I sourced my glass this eBay seller: http://www.ebay.com/usr/beetstech?_trksi...
To find the correct part, I followed iFixit's "ID your Mac" prompts in the parts store, then selected the glass panel from the list of compatible parts.
Hope this helps!
Noah Smith -
Is it useful for internal crack
tiffanyts - Réponse
FYI, OWC (Other World Computing, aka macsales.com) has the 15-inch glass for $25, and the 13-inch for $24:
https://eshop.macsales.com/item/Apple/MB... (15-inch)
https://eshop.macsales.com/item/Apple/MB... (13-inch)
…and I just discovered they even have the 17-inch:
One last comment: get the glass as hot as you can!
jiclark - Réponse
Does this work for the Late-2013 Retina MacBook Pro (15-inch)?
Brian Shiau - Réponse
There’s a rubber seal, or bumper around the outside of the glass, does the new screen get pressed under that rubber or does it just sort of fit within it? Anyone have unexpected difficulties with this?
johnocarney - Réponse
looks like it stays behind if you check the close-ups on step 6
Adam Tolley -
hello where can i find a new Screen Glass for my MacBook Pro Retina 15-inch Mid 2014 ?? can anyone help me please ??
sebastian.buchheit - Réponse
you can find it for about 15 bucks on amazon
David bellows -
Just to confirm, replacing the glass will fix the issue with the delaminated screen that is a known issue for this model of macbook pro
David Emerson - Réponse
Does this work for mid-2010 13” MBP unibody?
Edward Meyer - Réponse
Whatever you do, check the camera wiring is safe inside it’s groove. I just broke a glass because the wire wasn’t inside the groove when I pressed down. I’m a dumbass!
Dave Watkin - Réponse
Just replaced glass on a 15” unibody mid-2012 MBP. Great tutorial! Shattered glass (like mine was) seemed much trickier to remove (can’t get a good suction on cracked glass, and it keeps cracking during removal). Also, it would have been helpful to know about how long to use the hair dryer for those steps.
Paul Keew - Réponse
Before proceeding, readers really need to check the comments, and also get a 2nd opinion - such as from YouTube videos of other users, and the actualy article created by iFixit Staff Writers: Remplacement de la vitre avant de l'écran du MacBook Pro 13" Unibody mi-2009
The title of this article is unfortunately vague enough so that it attracts a lot of views from search engine results - even though it only applies just to the MacBook Pro 13-inch Unibody A1286 model - and not other models like the MacBook Pro Retina or (shudder) Touchbar. The actual iFixit staff-written guide is also limited to show under the replacement guides of the 2009 & 2010 variants of the A1286 MacBook Pro 13-inch Unibody even though the screen and front glass are constructed the same as each other for the subsequent years (2011 - 2012). Finally - this process is actually tricky enough to challenge experienced glaziers & repairers - so it needs a panel of writers & technicians to collaborate with a proper guide.
Jon T. - Réponse
WARNING: Do not melt your function keys with the hair dryer… Yup, you’re welcome.
Simon Holmes - Réponse
I was spraying windex on the screen rather than on a towel and wiping and some of the windex must have trickled down to some screen electrical component. Now I just have a grey screen. This is probably not the type of screen replacement I need.
Timothy Holmes - Réponse
Does this work for a MacBook Pro Retina 13”, early 2015? I cannot find the glass replacement for this model so i assume it is not.
Xabier - Réponse
I can’t manage to find the glass for the 13 inches 2015 early either ….
bogdanel1000 -
I have an Apple MacBook Pro 15 inch Mid-2015 MacBookPro11,4 A1398 MJLQ2LL/A. I think it’s a Retina Unibody model. The display glass isn’t broken but the glue has come off. Can I re-glue the glass this way? Do I have to remove it as illustrated above? Or can I just re-glue it by warming it up? I’m afraid the adhesive is on the whole display surface.
Toni Catany - Réponse
Sirve para MacBook Pro (Retina, 15 pulgadas, mediados de 2015)?
paco - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 20
7 derniers jours : 117
30 derniers jours : 509
Total : 129,470
