Aller au contenu principal
Remplacement du boîtier inférieur des MacBook Pro 15" Unibody fin 2008 et début 2009
Ce dont vous avez besoin
  1. Remplacement du boîtier inférieur des MacBook Pro 15" Unibody fin 2008 et début 2009, Trappe d'accès: étape 1, image 1 de 2 Remplacement du boîtier inférieur des MacBook Pro 15" Unibody fin 2008 et début 2009, Trappe d'accès: étape 1, image 2 de 2
    • Boîtier fermé, placez l'Unibody à l'envers sur une surface plane.
    • Appuyez sur le côté rainuré du loquet de déverrouillage de la trappe d'accès de manière à saisir l'extrémité libre du loquet. Soulevez le loquet de déverrouillage à la verticale.
    The A1286 has no Access Door.!!
    I actually can see no sign of the battery!...
    aguib - Réponse
    Citation de aguib :
    I assume you have the newer model, with the built-in battery. It's still removable with tools, but these are the wrong instructions for that model.
    lgc90 - Réponse
    when will there be a guide for the other unibody macbook pro. that does not have an access door?
    irishking - Réponse
    Is there a manual to show, how disasembly the display, i mean, after step 5, to check the display between lcd and aluminiun back case?
    Max
    Max - Réponse
    On other guides you state the height of the HD that can be supported, e.g. Remplacement du disque dur du MacBook Pro 15" Core 2 Duo modèle A1211 , I have read ( but have not confirmed ) that the uni-body MacBook Pro can be fitted with the 750GB and 1TB 12mm drive from Western Digital.
    Can you confirm this?
    Many thanks in advance.
    ahothabeth - Réponse
    Citation de SHerwood Ball :
    My display and aluminum casing has separated.
    I don't know if it just snaps back together or does it need to be glued.
    I dropped mine on the carpeted stairs and the display still works.
    I'm hoping I can just snap it back together and that no plastic pieces or teeth of the snapping
    portion have been broken........
    SHerwood Ball - Réponse
    When you say "left fan" is this "left when looking at the logic board after turning the computer over and looking it up opening it up" or "left when sitting at the computer keyboard and typing on it"?
    thvv - Réponse
    We always use left and right in reference to the computer when you're using it.
    Andrew Optimus Goldheart -
    Directions were great and the worn dc in board was replaced. The hardest part of the procedure is disconnecting the data display cable. A better description of step 21 is to slide the connector parallel to the circuit board towards the outside corner. Reconnecting correctly took several tries.
    I used the tip of the spudger to nudge the corners a little at a time to seat the connector.
    The ribbon connector for the keyboard has to be inserted all the way before seating the retaining cap. It took me three tries . First try power button did not work second try numbers keys did not work.
    Thanks for the directions ...could not have done it with out them!!!
    landryd - Réponse
    Hola. Poseo un MacBook Pro Late 2008 y debo cambiarle las cornetas. Me sirve unas cornetas de un MBP Late 2011?
    jegonzalez80 - Réponse
    Please read the instructions about removing the bluetooth cable - you CAN work around it, and NOT take off the plug.
    kenneth krabat - Réponse
  2. Remplacement du boîtier inférieur des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 2, image 1 de 1
    • La trappe d'accès est à présent suffisamment relevée pour la basculer et la retirer de l'Unibody.
  3. Remplacement du boîtier inférieur des MacBook Pro 15" Unibody fin 2008 et début 2009, Batterie: étape 3, image 1 de 1
    • Assurez-vous que la languette de la trappe d'accès est bien à la verticale avant de commencer.
    • Tirez sur la languette et retirez la batterie de votre MacBook.
    • Si la languette n'est pas bien positionnée, elle empêchera la batterie de sortir.
    Do I need to wait for the battery to charge completely before using the computer (while plugged in)?
    Kaila Potts - Réponse
    No. You do not need to charge it completely before removing it.
    Titus (#1579) - Réponse
  4. Remplacement du boîtier inférieur des MacBook Pro 15" Unibody fin 2008 et début 2009, Boîtier inférieur: étape 4, image 1 de 1
    • Retirez les huit vis suivantes par lesquelles le boîtier inférieur est fixé au châssis :
    • Une vis Phillips 5,4 mm.
    • Trois vis Phillips 14 mm.
    • Quatre vis Phillips 3,5 mm.
    Hi, My name is Jess I need help asap I accidentally dropped my macbook Pro and i cant find the silver screw for the top left back side, Does any one know if I can replace it with an eye glass screw?? If you can help at all Please e-mail me at Chambliss_jess@yahoo.com thx please help me my bf is going off... ;(
    Jess - Réponse
    The fixit PH00 is the wrong screw driver for this entire job. It did not fit in the screws, it was too pointy and caused screws to be rounded off.
    mattrittgers - Réponse
  5. Remplacement du boîtier inférieur des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 5, image 1 de 1
    • En vous servant des deux mains, soulevez le boîtier inférieur et retirez-le du boîtier supérieur.
    About midway along each edge is a snap. To release each snap, gently slide the flat edge of a Spudger under the lower case, then lift the lower case away.
    jonathansturges - Réponse
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
17 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
2 commentaires
My only comment is that the 00 phillips does not work it requires the #000. I brought my laptop to the hardware store to purchase the correct phillips.
joseph domini - Réponse
Does anyone know where to get the Four 3.5 mm Phillips screws? It is extremely difficult to find.
Thx
alfonso Velasquez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 48
Total : 24,431
