Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Replacing an Invisible Zipper
Ce dont vous avez besoin
  1. Replacing an Invisible Zipper, Invisible Zipper: étape 1, image 1 de 3 Replacing an Invisible Zipper, Invisible Zipper: étape 1, image 2 de 3 Replacing an Invisible Zipper, Invisible Zipper: étape 1, image 3 de 3
    • Prepare sewing machine with its compatible invisible zipper foot.
    • Thread the needle thread through the invisible zipper foot hole.
    • Pull the needle thread through the zipper foot hole.
    Demander à FixBot
    Ajouter un commentaire
  2. Replacing an Invisible Zipper: étape 2, image 1 de 3 Replacing an Invisible Zipper: étape 2, image 2 de 3 Replacing an Invisible Zipper: étape 2, image 3 de 3
    • Locate the stitch lines of where the broken zipper was sewn on both sides of your garment.
    • Use a seam ripper to carefully rip out both of the stitching lines.
    • Défaire une couture
    • Make sure to not cut through the fabric.
    • Remove old invisible zipper.
    Demander à FixBot
  3. Replacing an Invisible Zipper: étape 3, image 1 de 2 Replacing an Invisible Zipper: étape 3, image 2 de 2
    • Turn the skirt inside out.
    • Place the replacement invisible zipper on the table, with the teeth side pointing up and the zipper pull facing down.
    • Unzip the invisible zipper. Line up the left side of the tape of the invisible zipper with the left side of your fabric.
    • The zipper teeth should 1/8" away from the edge of the fabric.
    Demander à FixBot
  4. Replacing an Invisible Zipper: étape 4, image 1 de 2 Replacing an Invisible Zipper: étape 4, image 2 de 2
    • Pin the tape of the zipper to your garment's fabric perpendicular to the invisible zipper.
    Demander à FixBot
  5. Replacing an Invisible Zipper: étape 5, image 1 de 2 Replacing an Invisible Zipper: étape 5, image 2 de 2
    • Place the teeth of the left side of the zipper into the right side of the invisible zipper foot.
    • When repeating on the opposite side of the zipper, place the teeth of the right side of the zipper on the left side of the invisible zipper foot.
    Demander à FixBot
  6. Replacing an Invisible Zipper: étape 6, image 1 de 3 Replacing an Invisible Zipper: étape 6, image 2 de 3 Replacing an Invisible Zipper: étape 6, image 3 de 3
    • Sew a straight line carefully, removing pins as you go.
    • Repeat Steps 5-8 on the right side of your garment.
    Demander à FixBot
  7. Replacing an Invisible Zipper: étape 7, image 1 de 3 Replacing an Invisible Zipper: étape 7, image 2 de 3 Replacing an Invisible Zipper: étape 7, image 3 de 3
    • Turn the skirt right-side out again, so you don't see the zipper teeth.
    • Rotate the fabric so the zipper foot is perpendicular to the zipper tape.
    • Position the zipper foot on top of the fabric 1/8th of an inch from where the zipper tape meets the garment.
    • Sew back and forth at least 6 times to seal the end.
    • This ensures that the zipper tab does not come off when you zip it up.
    • Flip garment over to see the stitch line you just made. Cut off excess zipper tape.
    Demander à FixBot
  8. Replacing an Invisible Zipper: étape 8, image 1 de 3 Replacing an Invisible Zipper: étape 8, image 2 de 3 Replacing an Invisible Zipper: étape 8, image 3 de 3
    • Pull up your newly replaced zipper.
    • Be proud of yourself! You've just replaced an invisible zipper!
    Demander à FixBot
2 autres ont terminé cette réparation.
Katie Woo
Membre depuis le 04/28/17
125 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team S3-G2, Coad Spring 2017 Membre de l'équipe UC Davis, Team S3-G2, Coad Spring 2017
UCD-COAD-S17S3G2
3 membres
2 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 38
30 derniers jours : 161
Total : 14,043
