Aller au contenu principal
Revise The Saeco Odea support valve
Ce dont vous avez besoin
  1. Revise The Saeco Odea support valve, Revise the support valve: étape 1, image 1 de 2 Revise The Saeco Odea support valve, Revise the support valve: étape 1, image 2 de 2
    • Open the side flap and remove the brew group and coffee grounds container.
    • Unscrew the three Torx T10 screws on the cover above the support valve.
    • Take the lid off, now the support valve is open.
  2. Revise The Saeco Odea support valve: étape 2, image 1 de 2 Revise The Saeco Odea support valve: étape 2, image 2 de 2
    • The support valve is attached with four Torx T10 screws. Unscrew them.
    • Pull the valve forward to remove it. Then look for two o-rings. Replace the rings later during reinstallation.
  3. Revise The Saeco Odea support valve: étape 3, image 1 de 2 Revise The Saeco Odea support valve: étape 3, image 2 de 2
    • The seals on the support valve must be closed tightly with each brewing process and are heavily loaded. Replace them.
    • The support valve is closed with a cover with a bayonet lock. Using a flat screwdriver, turn the lid a few degrees counterclockwise and lift it out with a pair of pliers.
    • Check whether the inner parts (sliding piece, valve stem, and spring) can move freely and close tightly. Replace them if necessary.
Follow the steps in reverse order to reassemble your device.
Merci à ces traducteurs :
de en
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
VauWeh
Membre depuis le 10/19/15
165 900 Réputation
212 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 38
30 derniers jours : 119
Total : 3,809
