Aller au contenu principal
Rotor Riot Phone Connector Cable Replacement
Ce dont vous avez besoin
  1. Rotor Riot Phone Connector Cable Replacement, Remove the iPhone mount: étape 1, image 1 de 3 Rotor Riot Phone Connector Cable Replacement, Remove the iPhone mount: étape 1, image 2 de 3 Rotor Riot Phone Connector Cable Replacement, Remove the iPhone mount: étape 1, image 3 de 3
    • Use your fingers to remove the screw on the back side of the controller securing the iPhone mount.
    • Remove the iPhone mount.
  2. Rotor Riot Phone Connector Cable Replacement, Unscrew the back cover: étape 2, image 1 de 1
    • Use a T6 Torx screwdriver to remove the eight 9.2 mm-long screws securing the back cover.
    • Don't try to remove the back cover all the way yet! It's still connected to the mainboard.
  3. Rotor Riot Phone Connector Cable Replacement, Swing open the back cover: étape 3, image 1 de 3 Rotor Riot Phone Connector Cable Replacement, Swing open the back cover: étape 3, image 2 de 3 Rotor Riot Phone Connector Cable Replacement, Swing open the back cover: étape 3, image 3 de 3
    • Lift up the back cover of the controller.
    • Lift the back cover to a 45 degree angle and place it next to the controller.
    • Don't strain the interconnect cable during this procedure.
  4. Rotor Riot Phone Connector Cable Replacement, Disconnect the phone connector cable: étape 4, image 1 de 3 Rotor Riot Phone Connector Cable Replacement, Disconnect the phone connector cable: étape 4, image 2 de 3 Rotor Riot Phone Connector Cable Replacement, Disconnect the phone connector cable: étape 4, image 3 de 3
    • Use a spudger to disconnect the phone connector cable from the mainboard.
  5. Rotor Riot Phone Connector Cable Replacement, Remove the back cover: étape 5, image 1 de 1
    • Remove the back cover.
  6. Rotor Riot Phone Connector Cable Replacement, Remove the screw thread: étape 6, image 1 de 3 Rotor Riot Phone Connector Cable Replacement, Remove the screw thread: étape 6, image 2 de 3 Rotor Riot Phone Connector Cable Replacement, Remove the screw thread: étape 6, image 3 de 3
    • Pull the screw thread bracket straight up to slide it off of the rails securing it to the back cover.
  7. Rotor Riot Phone Connector Cable Replacement, Remove the phone connector cable: étape 7, image 1 de 3 Rotor Riot Phone Connector Cable Replacement, Remove the phone connector cable: étape 7, image 2 de 3 Rotor Riot Phone Connector Cable Replacement, Remove the phone connector cable: étape 7, image 3 de 3
    • Remove the phone connector cable.
Repair didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
Membre depuis le 12/18/19
43 604 Réputation
167 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
136 membres
15 170 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 160
