Aller au contenu principal
Ryobi CSB125 Motor Replacement
Ce dont vous avez besoin
  1. Ryobi CSB125 Motor Replacement, Motor: étape 1, image 1 de 1
    • Place the saw on a flat surface with the blade facing up.
    • Make sure that the saw is unplugged from any power source.
  2. Ryobi CSB125 Motor Replacement: étape 2, image 1 de 2 Ryobi CSB125 Motor Replacement: étape 2, image 2 de 2
    • Remove the bumper by using the T20 torx screwdriver to loosen the M5 x 20mm screw.
  3. Ryobi CSB125 Motor Replacement: étape 3, image 1 de 2 Ryobi CSB125 Motor Replacement: étape 3, image 2 de 2
    • Use the 7”/32 allen key to loosen the 5/16-18 x 9/16 in. blade screw.
  4. Ryobi CSB125 Motor Replacement: étape 4, image 1 de 1
    • Remove the 5/16-18 x 9/16 in. blade screw, spring washer, the outer blade washer, the blade, and the inner blade washer.
  5. Ryobi CSB125 Motor Replacement: étape 5, image 1 de 3 Ryobi CSB125 Motor Replacement: étape 5, image 2 de 3 Ryobi CSB125 Motor Replacement: étape 5, image 3 de 3
    • Use the #2 Phillip screwdriver to remove the four M4x16mm screws shown.
    • You will need to rotate the protective shell around in order to access them.
  6. Ryobi CSB125 Motor Replacement: étape 6, image 1 de 1
    • Remove the lower blade guard support assembly from the rest of the saw.
  7. Ryobi CSB125 Motor Replacement: étape 7, image 1 de 1
    • Flip the saw over and place the saw down on a flat surface with the motor facing up.
  8. Ryobi CSB125 Motor Replacement: étape 8, image 1 de 1
    • Use the Phillips #2 screwdriver to remove the five M4x16mm screws.
  9. Ryobi CSB125 Motor Replacement: étape 9, image 1 de 1
    • Use the Phillips #2 screwdriver to remove the two M45x35mm screws.
  10. Ryobi CSB125 Motor Replacement: étape 10, image 1 de 2 Ryobi CSB125 Motor Replacement: étape 10, image 2 de 2
    • Use the Phillips #2 screwdriver to remove the two M4x16mm screws holding down the end cover.
    • Pull off the end cover.
  11. Ryobi CSB125 Motor Replacement: étape 11, image 1 de 1
    • Use the Phillips #2 screwdriver to remove the M45x35mm screw holding down the motor housing.
  12. Ryobi CSB125 Motor Replacement: étape 12, image 1 de 1
    • Remove the motor housing for access to the internal motor components.
3 autres ont terminé cette réparation.
Curtis Melo
Membre depuis le 10/31/19
1 066 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G1, Barthe Fall 2019 Membre de l'équipe UMass Dartmouth, Team S2-G1, Barthe Fall 2019
UMASSD-BARTHE-F19S2G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 15
Total : 572
