Aller au contenu principal
Ryobi CSB125 Power Cord Replacement
Ce dont vous avez besoin
  1. Ryobi CSB125 Power Cord Replacement, Power Cord: étape 1, image 1 de 1
    • Place the saw down on a flat surface with the motor facing up.
    • Make sure that the saw is unplugged from any power source.
  2. Ryobi CSB125 Power Cord Replacement: étape 2, image 1 de 2 Ryobi CSB125 Power Cord Replacement: étape 2, image 2 de 2
    • Use the Phillips #2 screwdriver to remove the five M4x16mm screws.
  3. Ryobi CSB125 Power Cord Replacement: étape 3, image 1 de 1
    • Use the Phillips #2 screwdriver to remove the two M45x35mm screws.
  4. Ryobi CSB125 Power Cord Replacement: étape 4, image 1 de 2 Ryobi CSB125 Power Cord Replacement: étape 4, image 2 de 2
    • To remove the plug from the saw you will need to disconnect the two wires that come from the plug.
    • Remove the black wire by unscrewing it from the trigger switch using the Phillips #2 screwdriver.
    • Remove the white wire by twisting off the plastic wire nut to separate the two white wires.
  5. Ryobi CSB125 Power Cord Replacement: étape 5, image 1 de 1
    • Remove the plug from the saw.
    • You may have to use the wire strippers to expose the copper on the new plug.
    • It is important that the wires are properly run in their tracks. Failure to do so could result in pinching a wire, which could damage the plug.
4 autres ont terminé cette réparation.
Curtis Melo
Membre depuis le 10/31/19
1 066 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G1, Barthe Fall 2019 Membre de l'équipe UMass Dartmouth, Team S2-G1, Barthe Fall 2019
UMASSD-BARTHE-F19S2G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 10
30 derniers jours : 26
Total : 1,583
