Introduction
This guide will help you replace the buttons in your Sega Genesis Flashback controller. You’ll need a Phillips #000 screwdriver to complete this guide.
Ce dont vous avez besoin
Remove the screws on the back of the controller with the Phillips #000 screwdriver.
Hold the controller with the bottom plate facing up, gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
Use two fingers to remove each rubber membrane that rests on top of the buttons.
