Introduction
Before you can replace the internal components, you must remove the base plate, the blade, and the protective frame. The following pre-requisite guides may be helpful.
Ce dont vous avez besoin
Orient your saw so that the blade is pointing in the opposite direction of your body. Ensure that the screws circled are visible and pointing skyward. This will be the standard position of the Jigsaw for the duration of this guide.
Ensure that the Jigsaw is properly placed and that the blade is away from your body with the screws facing upward.
Identify the 10 screws circled for removal. Once all screws have been identified, use your Phillips screwdriver and begin removing them.
Be advised:If this is the first time opening up your tool, expect it to be very dirty. It is recommended you use a shamy cloth or wet rag to keep your hands clean.
At this point what lies in front of you should be a disassembled version of your SKIL 4235 Jigsaw.
