Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Epix LCD Display Replacement
Ce dont vous avez besoin
  1. Samsung Epix LCD Display Replacement, Battery: étape 1, image 1 de 1
    • Just below the phone's camera, press the button and hold it
    • While the button is held down, slide the back panel off to remove it completely.
    Demander à FixBot
  2. Samsung Epix LCD Display Replacement: étape 2, image 1 de 1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
    • Gently lift the battery and remove it from the phone.
    Demander à FixBot
  3. Samsung Epix LCD Display Replacement, LCD Display: étape 3, image 1 de 1
    • Remove the rubber screw cover in the top left corner by prying upwards with an opening tool.
    Demander à FixBot
  4. Samsung Epix LCD Display Replacement: étape 4, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone.
    • The upper right screw is 4.5 mm and the others are 6.5 mm.
    Demander à FixBot
  5. Samsung Epix LCD Display Replacement: étape 5, image 1 de 2 Samsung Epix LCD Display Replacement: étape 5, image 2 de 2
    • Slide the opening tool along the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
    Demander à FixBot
  6. Samsung Epix LCD Display Replacement: étape 6, image 1 de 1
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It will still be connected to the phone chassis by a ribbon cable on the motherboard.
    Demander à FixBot
  7. Samsung Epix LCD Display Replacement: étape 7, image 1 de 1
    • Using an opening tool, undo the ZIF connector halfway up the right side.
    • Carefully remove ribbon cable.
    Demander à FixBot
  8. Samsung Epix LCD Display Replacement: étape 8, image 1 de 1
    • Remove the front faceplate by lifting it off of the phone chassis.
    Demander à FixBot
  9. Samsung Epix LCD Display Replacement: étape 9, image 1 de 1
    • Using the opening tool, unlatch the LCD ribbon cable.
    Demander à FixBot
  10. Samsung Epix LCD Display Replacement: étape 10, image 1 de 1
    • Using an opening tool or spudger, pry under the lower left and right corners of the LCD screen.
    • The LCD is held in place to the chassis with adhesive strips.
    • Do not pry excessively hard. You may damage the circuitry on the back of the LCD.
    Demander à FixBot
  11. Samsung Epix LCD Display Replacement: étape 11, image 1 de 1
    • Lift the LCD display out from phone chassis.
    Demander à FixBot
Mark Wyse
Membre depuis le 04/19/11
62 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 15-15, Regan Spring 2011 Membre de l'équipe Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 86
Total : 2,186
