Introduction
Use this guide to replace a broken display or cracked glass of your Samsung Galaxy A5.
Ce dont vous avez besoin
Take an iOpener to heat up and soften the glue behind the back cover.
With a suction handle lift the back cover to insert an opening pick.
Outil utilisé dans cette étape :Plastic Cards$2.99
Insert a plastic card at the bottom and slide it underneath the back cover.
Heat up the back cover once again so you can slide the plastic card towards the top.
Move the plastic card until you reach the camera bump. Now slowly lift up the back cover and finally remove it.
Remove the SIM card tray.
Remove the 17 Phillips #00 screws on the midframe.
With a flat end of a spudger disconnect the display connector.
Reheat the iOpener and use it to loosen the adhesive under the display.
On the left hand side (where the motherboard sits) replace the opening pick with a plastic card to get to the glue behind the battery.
Continue separating the adhesive until you reach the display cable.
63 autres ont terminé cette réparation.
8 commentaires
dear sir,
i follow the steps above but still my mobile with black screen and colored dots, what shall i do please help me
Dear sir
Mera Mobile gir jane ke karan screen tut gya h but work kar rha mai chahta hu ise repair karwana please contact me Mobile -7903248447
Miei parole ci sono sei molto bravo , grazie mille per tutorial , e ti mandò un mondo di salute e più grande fortuna dell' mondo Grazie…..
Unfortunately, Croatian is not yet available on our site. A team of volunteers has already started localizing the iFixit user interface into Croatian, but there is still lots of work to do. We are using an open web translation software which is called "Crowdin". If you'd like to participate, you can just follow this link and create an account to start translating: https://crowdin.com/project/ifixit/hr# , but I would recommend that you read the iFixit translator guidelines first: Translator Guidelines Crowdin. If you’d like to get a notification as soon as we get started with Guide and Wiki translations in Croatian, you can just fill in this form:++ https://docs.google.com/forms/d/e/1FAIpQ.... I stay at your disposal for any further question or concern!
