Introduction
Use this guide to replace the rubber feet in your Galaxy Book Pro 360 15" laptop.
Ce dont vous avez besoin
Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
Insert an opening pick between the rear case and the rubber foot.
Pry up with the pick and dislodge the foot from the rear case.
Use tweezers or your fingers to remove the rubber foot.
Repeat this process on the remaining rubber feet.
To reassemble your device, follow the instructions in reverse order.
