Aller au contenu principal
Samsung Galaxy Buds Live Battery Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Buds Live Battery Replacement, Insert an opening pick: étape 1, image 1 de 2 Samsung Galaxy Buds Live Battery Replacement, Insert an opening pick: étape 1, image 2 de 2
    • If possible, discharge your Galaxy Buds Live before replacing the battery.
    • Place the tip of an opening pick between the plastic cases on the curved inside of the earbud.
    • Insert the pick at a steep angle.
  2. Samsung Galaxy Buds Live Battery Replacement, Loosen the case: étape 2, image 1 de 2 Samsung Galaxy Buds Live Battery Replacement, Loosen the case: étape 2, image 2 de 2
    • Keep the opening pick at a steep angle and slide it along the top to loosen the case.
    • Take your time and do your best not to deform the plastic.
  3. Samsung Galaxy Buds Live Battery Replacement, Remove the case: étape 3, image 1 de 2 Samsung Galaxy Buds Live Battery Replacement, Remove the case: étape 3, image 2 de 2
    • Remove the case.
  4. Samsung Galaxy Buds Live Battery Replacement, Disconnect the main connector: étape 4, image 1 de 2 Samsung Galaxy Buds Live Battery Replacement, Disconnect the main connector: étape 4, image 2 de 2
    • Use the pointed end of a spudger to lift up and disconnect the main connector.
  5. Samsung Galaxy Buds Live Battery Replacement, Remove the motherboard: étape 5, image 1 de 3 Samsung Galaxy Buds Live Battery Replacement, Remove the motherboard: étape 5, image 2 de 3 Samsung Galaxy Buds Live Battery Replacement, Remove the motherboard: étape 5, image 3 de 3
    • Use a spudger to gently lift up the motherboard.
    • Remove the motherboard.
  6. Samsung Galaxy Buds Live Battery Replacement, Unscrew the plastic frame: étape 6, image 1 de 1
    • Use a Phillips screwdriver to remove the 3.4 mm-long screw which is securing the plastic frame.
  7. Samsung Galaxy Buds Live Battery Replacement, Remove the plastic frame: étape 7, image 1 de 3 Samsung Galaxy Buds Live Battery Replacement, Remove the plastic frame: étape 7, image 2 de 3 Samsung Galaxy Buds Live Battery Replacement, Remove the plastic frame: étape 7, image 3 de 3
    • Use a spudger or your fingers to remove the plastic frame by pulling it upwards.
  8. Samsung Galaxy Buds Live Battery Replacement, Clear the battery: étape 8, image 1 de 2 Samsung Galaxy Buds Live Battery Replacement, Clear the battery: étape 8, image 2 de 2
    • Use the pointed end of a spudger to slightly lift up the speaker driver obscuring the battery.
    • The driver is held in place with light adhesive. Work carefully and don't tug on anything too hard.
  9. Samsung Galaxy Buds Live Battery Replacement, Pry up the battery: étape 9, image 1 de 3 Samsung Galaxy Buds Live Battery Replacement, Pry up the battery: étape 9, image 2 de 3 Samsung Galaxy Buds Live Battery Replacement, Pry up the battery: étape 9, image 3 de 3
    • The battery is held in place by a mild adhesive.
    • Insert the pointed end of a spudger underneath the battery.
    • Use constant, steady pressure to pry the battery up.
  10. Samsung Galaxy Buds Live Battery Replacement, Remove the battery: étape 10, image 1 de 1
    • Remove the battery.
    • Do not reinstall a damaged battery, as doing so is a potential safety hazard.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
7 autres ont terminé cette réparation.
Adriana Zwink
Membre depuis le 12/18/19
43 377 Réputation
167 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
136 membres
15 118 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 144
30 derniers jours : 570
Total : 10,336
