Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Core Display Replacement
  1. Samsung Galaxy Core Display Replacement, Display: étape 1, image 1 de 2 Samsung Galaxy Core Display Replacement, Display: étape 1, image 2 de 2
    • Turn the phone off
    • Remove the back cover
    • Extract battery
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Core Display Replacement: étape 2, image 1 de 1
    • Remove the 9 screws
    Demander à FixBot
  3. Samsung Galaxy Core Display Replacement: étape 3, image 1 de 1
    • Remove the central frame to access the motherboard, help yourself with a thin tool
    • Remove the black screw that secures the lower motherboard
    Demander à FixBot
  4. Samsung Galaxy Core Display Replacement: étape 4, image 1 de 3 Samsung Galaxy Core Display Replacement: étape 4, image 2 de 3 Samsung Galaxy Core Display Replacement: étape 4, image 3 de 3
    • Unclip the 3 connectors
    • Disconnect the connection cable of the 2 motherboards
    • With a flat instrument, help yourself to unhook the motherboard
    Demander à FixBot
  5. Samsung Galaxy Core Display Replacement: étape 5, image 1 de 3 Samsung Galaxy Core Display Replacement: étape 5, image 2 de 3 Samsung Galaxy Core Display Replacement: étape 5, image 3 de 3
    • Remove top motherboard
    • Remove Speaker
    • Remove the lower motherboard with the help of a hot air hairdryer to help it detach from the adhesive
    Demander à FixBot
  6. Samsung Galaxy Core Display Replacement: étape 6, image 1 de 2 Samsung Galaxy Core Display Replacement: étape 6, image 2 de 2
    • If the touch screen glass is broken, use tape to avoid injury
    • Disconnect the TouchScreen connector
    Demander à FixBot
  7. Samsung Galaxy Core Display Replacement: étape 7, image 1 de 1
    • Remove the touchscreen with thin tools between the glass and the central cover with the aid of a hair dryer or heat so that you can loosen the adhesive grip
    • Be careful in the part of the buttons and the flat cable of the touchscreen if you need to use it again and do not replace it with a new one
    Demander à FixBot
  8. Samsung Galaxy Core Display Replacement: étape 8, image 1 de 3 Samsung Galaxy Core Display Replacement: étape 8, image 2 de 3 Samsung Galaxy Core Display Replacement: étape 8, image 3 de 3
    • Remove the display with thin tools, using heat to detach the fixing adhesive
    Demander à FixBot
To Reassemble your device, Follow these instruction reverse order.
3 autres ont terminé cette réparation.
Merci à ces traducteurs :
it en
100%
irlanda nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Smilzo
Membre depuis le 11/09/13
12 338 Réputation
39 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 24
Total : 1,761
