Introduction
This guide will teach how to replace the motherboard in your Samsung Galaxy 10.1 2014 edition.
Ce dont vous avez besoin
Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
Remove the three 3mm screws on the top right side of the device with the Phillips PH000 screw head.
Remove the one 3mm screw on the top left side of the device with the same method.
Remove the gray rubber piece.
Use a spudger or fingernail to disconnect the blue antenna cable from the motherboard.
Remove the right speaker unit.
Place your finger on the thin black bar at the end of the ribbon tape and flip each one up.
Gently pull the ribbon tape on the battery away from the bar. Repeat this process for the second ribbon tape.
Remove the six 3mm screws around the battery with the Phillips PH000 screwdriver.
Lift up the battery from the bottom and situate the black nylon spudger underneath the battery.
Use the black nylon spudger to disconnect the multi-colored wires from the rest of the device.
7 autres ont terminé cette réparation.
5 commentaires
hi. i have one of this tablets and i need a ic guide for it. something like this link :
Samsung Galaxy Note 10.1 Teardown
this like is for galaxy note 10.1 2012 but i need it for 2014 (SM-P601).
any documents or files to help me recognize which Chip do what ?
Can I use this motherboard with Galaxy note 10.1 GT-N8000 ? Plz reply fast
Can I use this motherboard with Galaxy Note 10.1 GT-N8000 ? Plz reply fast
miss 1 screw when removing the motherboard on the center right side
