Aller au contenu principal
Samsung Galaxy Note 10.1 Front-Facing Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Top Piece: étape 1, image 1 de 3 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Top Piece: étape 1, image 2 de 3 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Top Piece: étape 1, image 3 de 3
    • This is the back of the device and where you willl begin to take it apart
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Back Cover: étape 2, image 1 de 3 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Back Cover: étape 2, image 2 de 3 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Back Cover: étape 2, image 3 de 3
    • Unscrew the three screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Camera: étape 3, image 1 de 3 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Camera: étape 3, image 2 de 3 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Camera: étape 3, image 3 de 3
    • Start by lifting the white connector to remove the part indicated by the red polygon.
    • Gently pry along the camera hub to lift it out of its location.
    • This is your camera. Replace it with the new part.
  4. Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Front-Facing Camera: étape 4, image 1 de 3 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Front-Facing Camera: étape 4, image 2 de 3 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Front-Facing Camera: étape 4, image 3 de 3
    • Now that you have removed the rear-facing camera, you can access the front-facing camera.
    • To remove the front-facing camera, start by lifting the white connector to remove the part indicated by the marker.
    • Gently pull the front-facing camera out of its casing.
Rachel Dykes
Membre depuis le 11/04/19
205 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 15
Total : 341
