Aller au contenu principal
Samsung Galaxy Note Headphone Jack and Earpiece Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Samsung Galaxy Note Headphone Jack and Earpiece Replacement, Battery: étape 1, image 1 de 3 Samsung Galaxy Note Headphone Jack and Earpiece Replacement, Battery: étape 1, image 2 de 3 Samsung Galaxy Note Headphone Jack and Earpiece Replacement, Battery: étape 1, image 3 de 3
    • Make sure the screen is face-down and the camera is opposite you.
    • Insert the flat end of a spudger into the phone's top right rectangular slot.
    • Use the spudger as a lever to pry open the back of the phone.
  2. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: étape 2, image 1 de 1
    • With the spudger still inserted, carefully slide the spudger down the side of the phone.
    • Gently peel off the back cover with your hand.
  3. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: étape 3, image 1 de 1
    • Place the spudger in the battery's bottom right slot.
    • Gently pry to remove the battery.
  4. Samsung Galaxy Note Headphone Jack and Earpiece Replacement, Midframe: étape 4, image 1 de 1
    • Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
  5. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: étape 5, image 1 de 1
    • Remove the stylus from the bottom of the phone.
  6. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: étape 6, image 1 de 3 Samsung Galaxy Note Headphone Jack and Earpiece Replacement: étape 6, image 2 de 3 Samsung Galaxy Note Headphone Jack and Earpiece Replacement: étape 6, image 3 de 3
    • Pry all the way around the sides with a plastic pry tool and gently pop off the midframe.
    • If the cover does not come off easily, continue to pry along the phone's perimeter.
    • This step can take some patience. Prying too hard or forcing the screen off can crack or scratch the screen and break the thin plastic around the stylus case.
    • Separate the midframe from the phone. The midframe should now pull off easily.
  7. Samsung Galaxy Note Headphone Jack and Earpiece Replacement, Headphone Jack and Earpiece: étape 7, image 1 de 1
    • Use the spudger to pry up the yellow ribbon cable.
  8. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: étape 8, image 1 de 1
    • Use the spudger to pry up the long, green ribbon next to the yellow one you just pried up.
    • Push the green ribbon back to access the black bracket underneath it.
  9. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: étape 9, image 1 de 1
    • Use your fingers to gently lift up the black bracket and set it aside.
  10. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: étape 10, image 1 de 2 Samsung Galaxy Note Headphone Jack and Earpiece Replacement: étape 10, image 2 de 2
    • Flip the spudger around and insert the pointy end into the headphone jack.
    • Lift the headphone jack directly upwards using the spudger as a lever. This will also remove the connected speaker.
    • The headphone jack and earpiece are held down with an adhesive, so removing them might take some force.
David Ritter
Membre depuis le 04/14/13
758 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 3-45, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 3-45, Amido Spring 2013
CPSU-AMIDO-S13S3G45
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,069
