Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Prevail 2 Home Button Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Prevail 2 Home Button Replacement, Removing Back Casing: étape 1, image 1 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Removing Back Casing: étape 1, image 2 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Removing Back Casing: étape 1, image 3 de 3
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Battery: étape 2, image 1 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Remove Battery: étape 2, image 2 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Remove Battery: étape 2, image 3 de 3
    • Gently pull the battery out of the phone.
    Demander à FixBot
  3. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Screws: étape 3, image 1 de 2 Samsung Galaxy Prevail 2 Home Button Replacement, Remove Screws: étape 3, image 2 de 2
    • Unscrew all of the screws.
    • Be sure to set aside in a safe place.
    Demander à FixBot
  4. Samsung Galaxy Prevail 2 Home Button Replacement, Pry Off Back of Phone: étape 4, image 1 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Pry Off Back of Phone: étape 4, image 2 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Pry Off Back of Phone: étape 4, image 3 de 3
    • Insert the plastic opening tool between the silver frame and the white face of the phone to pry off the front face.
    • Make sure to pry around the entire frame to loosen it before proceeding.
    • Use your thumbs to separate the motherboard from the back of the phone
    Demander à FixBot
  5. Samsung Galaxy Prevail 2 Home Button Replacement, Open Up the Motherboard: étape 5, image 1 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Open Up the Motherboard: étape 5, image 2 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Open Up the Motherboard: étape 5, image 3 de 3
    • With the plastic opening tool, lift up the flap to to fully open the motherboard.
    Demander à FixBot
  6. Samsung Galaxy Prevail 2 Home Button Replacement, Detach Motherboard: étape 6, image 1 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Detach Motherboard: étape 6, image 2 de 3 Samsung Galaxy Prevail 2 Home Button Replacement, Detach Motherboard: étape 6, image 3 de 3
    • With the plastic opening tool, lift the second flap up.
    Demander à FixBot
  7. Samsung Galaxy Prevail 2 Home Button Replacement, Locate Home Button: étape 7, image 1 de 2 Samsung Galaxy Prevail 2 Home Button Replacement, Locate Home Button: étape 7, image 2 de 2
    • Choose the motherboard side that contains the home button, as shown in the image.
    Demander à FixBot
  8. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Home Button: étape 8, image 1 de 2 Samsung Galaxy Prevail 2 Home Button Replacement, Remove Home Button: étape 8, image 2 de 2
    • Use the plastic opening tool to push the home button out.
    • Push the button from the face of the phone inwards as indicated in the first image.
    Demander à FixBot
7 autres ont terminé cette réparation.
Garrett Bowleg
Membre depuis le 10/08/14
487 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 14-4, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
4 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 23
Total : 2,468
