Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Prevail 2 Vibrator Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: étape 1, image 1 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: étape 1, image 2 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: étape 1, image 3 de 3
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: étape 2, image 1 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: étape 2, image 2 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: étape 2, image 3 de 3
    • Gently pull the battery out of the phone.
    Demander à FixBot
  3. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Screws: étape 3, image 1 de 2 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Screws: étape 3, image 2 de 2
    • Unscrew all of the screws.
    • Be sure to set the screws aside in a safe place.
    Demander à FixBot
  4. Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: étape 4, image 1 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: étape 4, image 2 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: étape 4, image 3 de 3
    • Insert the plastic prying tool between the silver frame and the white face of the phone. to pry off the front frame.
    • Make sure to pry around the entire frame to loosen it before proceeding.
    • Use your thumbs to separate the motherboard from the back of the phone.
    Demander à FixBot
  5. Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: étape 5, image 1 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: étape 5, image 2 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: étape 5, image 3 de 3
    • With the plastic prying tool, lift up the flap in order to fully open the motherboard.
    Demander à FixBot
  6. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: étape 6, image 1 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: étape 6, image 2 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: étape 6, image 3 de 3
    • With plastic prying tool, lift the flap up to divide the motherboard.
    • This will make it easier to detach the internal battery.
    Demander à FixBot
  7. Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: étape 7, image 1 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: étape 7, image 2 de 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: étape 7, image 3 de 3
    • With plastic prying tool, lift up the vibration motor.
    Demander à FixBot
  8. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Vibration Motor: étape 8, image 1 de 1
    • With the soldering iron remove the solder attaching the vibration motor to the motherboard.
    Demander à FixBot
5 autres ont terminé cette réparation.
Garrett Bowleg
Membre depuis le 10/08/14
487 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 14-4, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
4 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 43
Total : 1,414
