Aller au contenu principal
Samsung Galaxy S8 Plus Display Adhesive Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S8 Plus Display Adhesive Replacement, Display Adhesive: étape 1, image 1 de 3 Samsung Galaxy S8 Plus Display Adhesive Replacement, Display Adhesive: étape 1, image 2 de 3 Samsung Galaxy S8 Plus Display Adhesive Replacement, Display Adhesive: étape 1, image 3 de 3
    • Remove all traces of adhesive and debris from the phone's frame. Clean the adhesion surface with high concentration isopropyl alcohol (over 90%) and wipe it clean with a lint-free cloth.
    • If glue or glass remnants are left behind, the new display will not mount correctly and may be damaged.
    • Lay the adhesive strips out to get an idea of where they go.
    • Peel off the clear plastic backing from the large pre-cut adhesive strip, exposing one side of adhesive.
  2. Samsung Galaxy S8 Plus Display Adhesive Replacement: étape 2, image 1 de 3 Samsung Galaxy S8 Plus Display Adhesive Replacement: étape 2, image 2 de 3 Samsung Galaxy S8 Plus Display Adhesive Replacement: étape 2, image 3 de 3
    • Carefully line up a long edge of the adhesive with the edge of the phone frame.
    • Make sure that the adhesive cutouts match the phone's.
    • Set the adhesive down lightly on the frame.
    • If it is not properly aligned, carefully peel the adhesive back up.
    • Once the adhesive is aligned, use your fingers to press the adhesive onto the frame.
  3. Samsung Galaxy S8 Plus Display Adhesive Replacement: étape 3, image 1 de 3 Samsung Galaxy S8 Plus Display Adhesive Replacement: étape 3, image 2 de 3 Samsung Galaxy S8 Plus Display Adhesive Replacement: étape 3, image 3 de 3
    • Peel one of the end adhesive strips from the clear plastic backing.
    • The strips are cut for a specific end and are not interchangeable.
    • Hold the strip by the two green end tabs and line the adhesive strip with the phone frame.
    • Lay the adhesive down lightly on the phone. Make sure that all cutouts are properly aligned.
    • Once aligned, use your fingers to press the adhesive into place.
    • Repeat the procedure for the remaining adhesive strip.
  4. Samsung Galaxy S8 Plus Display Adhesive Replacement: étape 4, image 1 de 1
    • Continue reassembling your device until you are ready to attach the screen.
    • If possible, test your screen's functionality before sticking it in place.
    • Peel and remove the green plastic liner from all adhesive strips to expose the screen-facing adhesive.
    • Align and set the phone screen on top of the adhesive.
    • Use your fingers to squeeze around the perimeter of the phone to set the adhesive.
    • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
Follow this link to return to the Galaxy S8+ screen replacement guide.
10 autres ont terminé cette réparation.
Arthur Shi
Membre depuis le 01/03/18
287 692 Réputation
595 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
120 membres
20 903 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 31
Total : 6,635
