Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement, Rear Glass Removal: étape 1, image 1 de 1
    • Switch off your phone.
    • Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • The adhesive of the Samsung Galaxy S9 Plus is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 2, image 1 de 1
    • In the following steps, you'll be cutting through the adhesive securing the back cover.
    • The adhesive in the inside of the back cover is laid out as seen in the image.
    • You'll be slicing through the adhesive in the areas shown:
    • Thick portions of adhesive
    • Thin areas of adhesive
    • Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
    Demander à FixBot
  3. Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 3, image 1 de 2 Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 3, image 2 de 2
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
    • Insert an opening pick in the gap and slide it to the bottom right corner.
    Demander à FixBot
  4. Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 4, image 1 de 2 Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 4, image 2 de 2
    • Insert a second opening pick and slide it to the bottom left corner.
    • Insert a third opening pick at the bottom end of the phone. This opening pick stays there during the rear glass removal procedure to prevent the adhesive from resealing.
    Demander à FixBot
  5. Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 5, image 1 de 2 Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 5, image 2 de 2
    • Start to slide the tip of the opening pick from the bottom left corner along the side of the S9 Plus.
    • Leave the opening pick in its place after you cut the adhesive half way up the left side of the phone.
    • Slide the opening pick from the bottom right corner half way up the frame and leave it there.
    Demander à FixBot
  6. Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 6, image 1 de 2 Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 6, image 2 de 2
    • Insert a fourth opening pick at the right side of the frame and slide it to the top right corner.
    • Slide a fifth opening pick along the left side of the phone to the top left corner.
    • Use the opening pick to cut the remaining adhesive under the upper part of the rear glass.
    • Don't open the phone all the way yet. The flex cable for the fingerprint reader is still connected to the motherboard.
    Demander à FixBot
  7. Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 7, image 1 de 2 Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 7, image 2 de 2
    • Carefully lift the side of the rear glass where the volume button is located.
    • Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
    Demander à FixBot
  8. Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 8, image 1 de 1
    • Remove the rear glass.
    • When reassembling follow this guide to replace the adhesive and reinstall the rear glass.
    • In case you want to replace your rear glass follow this guide to transfer the rear camera bezel including the fingerprint.
    Demander à FixBot
  9. Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement, Camera Lens Cover: étape 9, image 1 de 1
    • Apply a heated iOpener to the rear camera lens cover. Apply the iOpener for at least two minutes.
    • The adhesive under the rear camera bezel is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone.
    Demander à FixBot
  10. Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 10, image 1 de 2 Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 10, image 2 de 2
    • Slide an opening pick between the top edge of the bezel and the rear glass.
    • If you can't manage to insert an opening pick between rear glass and the rear camera bezel, you can try to cut the adhesive with a playing card.
    • Use the opening pick to cut the adhesive beneath the upper part of the bezel.
    Demander à FixBot
  11. Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 11, image 1 de 3 Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 11, image 2 de 3 Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 11, image 3 de 3
    • Insert the opening pick beneath the right side of the rear camera bezel.
    • Slide the opening pick along the bezel to cut the adhesive.
    • Twist the opening pick sideways to pry up the rear camera bezel including the fingerprint sensor.
    Demander à FixBot
  12. Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 12, image 1 de 2 Samsung Galaxy S9 Plus Fingerprint Sensor and Camera Lens Cover Replacement: étape 12, image 2 de 2
    Outil utilisé dans cette étape :
    • Use a pair of tweezers to remove the rear camera bezel including the fingerprint sensor.
    • If you're going to apply new adhesive remove any remaining adhesive from the bezel and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Follow this general Galaxy S adhesive guide for applying new adhesive on the rear camera bezel and the rear glass.
    Demander à FixBot
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
After you've completed the repair, follow this guide to test your repair.
15 autres ont terminé cette réparation.
Dominik Schnabelrauch
Membre depuis le 11/23/16
260 714 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
27 557 tutoriels rédigés
1 commentaire de tutoriel
Ottimo lavoro
mimmo marley - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 86
Total : 14,583
