Aller au contenu principal
Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement, Rear Glass Removal: étape 1, image 1 de 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
    • You might need to reheat and reapply the iOpener several times during the removal procedure to get the adhesive warm enough to cut. Follow the iOpener instructions to avoid overheating.
    • The adhesive of the Samsung Galaxy S9 is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 2, image 1 de 1
    • In the following steps, you'll be cutting through the adhesive securing the back cover.
    • The adhesive in the inside of the back cover is laid out as seen in the image.
    • You'll be slicing through the adhesive in the areas shown:
    • Thick portions of adhesive
    • Thin areas of adhesive
    • Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
  3. Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 3, image 1 de 3 Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 3, image 2 de 3 Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 3, image 3 de 3
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
    • Insert an opening pick in the gap you created and slide it to the bottom right corner.
    • Insert a second opening pick and slide it to the bottom left corner.
    • Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
  4. Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 4, image 1 de 2 Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 4, image 2 de 2
    • While inserting only the tip of the opening pick, slide it from the bottom left corner along the side to the top.
    • Slide the pick around the top corner and leave it there to prevent the adhesive from resealing.
  5. Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 5, image 1 de 3 Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 5, image 2 de 3 Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 5, image 3 de 3
    • Slide the opening pick from the bottom right corner along the side to the top.
    • Apply more heat if the adhesive becomes hard to cut. During the removal process, the back cover is under tension all the time and is likely to break if the adhesive isn't softened enough.
    • Slide the opening pick around the corner and cut the remaining adhesive at the top of the phone.
    • Don't open the phone all the way yet. The fragile fingerprint sensor cable still connects the back cover to the motherboard.
  6. Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 6, image 1 de 2 Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 6, image 2 de 2
    • Carefully lift the side of the rear glass where the volume button is located.
    • Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
  7. Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 7, image 1 de 1
    • Remove the rear glass.
    • When reassembling follow this guide to replace the adhesive and reinstall the rear glass.
    • In case you want to replace your rear glass follow this guide to transfer the rear camera bezel including the fingerprint.
  8. Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement, Camera Lens Cover: étape 8, image 1 de 1
    • Apply a heated iOpener to the rear camera lens cover. Apply the iOpener for at least two minutes.
    • The adhesive under the rear camera bezel is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone.
  9. Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 9, image 1 de 2 Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 9, image 2 de 2
    • Slide an opening pick between the top edge of the bezel and the rear glass.
    • If you can't manage to insert an opening pick between rear glass and the rear camera bezel, you can try to cut the adhesive with a playing card.
    • Use the opening pick to cut the adhesive beneath the upper part of the bezel.
  10. Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 10, image 1 de 3 Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 10, image 2 de 3 Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 10, image 3 de 3
    • Insert the opening pick beneath the right side of the rear camera bezel.
    • Slide the opening pick along the bezel to cut the adhesive.
    • Twist the opening pick sideways to pry up the rear camera bezel including the fingerprint sensor.
  11. Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 11, image 1 de 2 Samsung Galaxy S9 Rear Camera Bezel With Fingerprint Sensor Replacement: étape 11, image 2 de 2
    Outil utilisé dans cette étape :
    • Use a pair of tweezers to remove the rear camera bezel including the fingerprint sensor.
    • If you're going to apply new adhesive remove any remaining adhesive from the bezel and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Follow this general Galaxy S adhesive guide for applying new adhesive on the rear camera bezel and the rear glass.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
After you've completed the repair, follow this guide to test your repair.
15 autres ont terminé cette réparation.
Dominik Schnabelrauch
Membre depuis le 11/23/16
246 910 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
23 648 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 45
Total : 9,724
