Aller au contenu principal
Il est possible que cette traduction ne reflète pas les dernières mises à jour du tutoriel source. Aidez à mettre à jour la traduction ou bien consultez le tutoriel source.
Remplacement du panneau arrière du Samsung Galaxy Tab 10.1
Ce dont vous avez besoin
  1. Remplacement du panneau arrière du Samsung Galaxy Tab 10.1, Panneau arrière: étape 1, image 1 de 2 Remplacement du panneau arrière du Samsung Galaxy Tab 10.1, Panneau arrière: étape 1, image 2 de 2
    • Placez le bas de la tablette vers vous.
    • Retirez les deux vis de 4,1 mm près du port de charge avec un tournevis Tri-Wing.
    Access denied! The screws near the port are covered by buttons. I wedged a pointed screw and hammered "gently" until they popped out. Problem solved!
    Daniella - Réponse
    My model doesn't have any screws!
    Barry - Réponse
    What can I do if my model DOESN'T HAVE ANY SCREWS? It has a loose LCD cable so SOME of my colours are all mixed up. This is really frustrating so please help
    Janine Coetzee - Réponse
    I have SG Tab Pro 10.1
    There are no screws..... now what?
    iloveto travel - Réponse
    Great instructions! Easy to follow.
    skritzberger - Réponse
    My model has no screws.
    Faith Odutola - Réponse
    My model has no screws and doesn't look like the one pictured here. It's a model SM-T580.
    Elsa Kramer - Réponse
    Be careful removing the two screw plugs by the 30 pin connector. They are easy to scratch. I couldn’t get the plugs out with my tool kit and finally removed them with the point of an exacto knife.
    Behind the two plugs are sticky pads that will need to be handled carefully and saved for reassembly.
    If you order a tool kit online, be sure it has a Y1 tri-wing screwdriver. The one in my kit was not Y1 and would not remove the screws.
    I had to order a new screwdriver.
    George Tomlinson - Réponse
    I don't see any screws I have a galaxy tab 4
    Tammylynn Gmarter - Réponse
    if your model doesn’t have these screws, it’s probably ok to just skip this step. at least that’s what i did on model gt-p7500, and that repair was successful (battery replacement). Janine, a friend asked me to fix his Tab where that had happened when he tried to replace the battery himself… i just took out the 3 big cables over the battery, and re-inserted them, and that fixed the problem. you should try that if you haven’t already..
    divinity76 - Réponse
    Mine doesn't have screws so what do I do now?
    katrinawisner - Réponse
    charging samsung battery dabka ilaaliyo
    Maxamed Xuseen - Réponse
  2. Remplacement du panneau arrière du Samsung Galaxy Tab 10.1: étape 2, image 1 de 3 Remplacement du panneau arrière du Samsung Galaxy Tab 10.1: étape 2, image 2 de 3 Remplacement du panneau arrière du Samsung Galaxy Tab 10.1: étape 2, image 3 de 3
    • Commencez au milieu du côté gauche et insérez un outil d'ouverture en plastique entre le panneau arrière et l'ensemble du panneau avant.
    • Passez soigneusement l'outil d'ouverture en plastique le long du bord gauche et supérieur pour écarter le panneau arrière du reste de l'appareil.
    • Placez les ouvertures d'ouverture le long du côté que vous avez déjà ouvert afin de garder le panneau arrière détaché du reste de l'appareil.
    • Assurez-vous de travailler soigneusement, car le curseur peut aussi craquer l'écran.
  3. Remplacement du panneau arrière du Samsung Galaxy Tab 10.1: étape 3, image 1 de 3 Remplacement du panneau arrière du Samsung Galaxy Tab 10.1: étape 3, image 2 de 3 Remplacement du panneau arrière du Samsung Galaxy Tab 10.1: étape 3, image 3 de 3
    • À l'aide des outils d'ouverture en plastique, continuez à parcourir soigneusement le bord droit et inférieur, puis soulevez l'écran à partir du panneau arrière.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
13 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
85%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Davie Sy
Membre depuis le 09/30/13
1 430 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 13-5, Forte Fall 2013 Membre de l'équipe Cal Poly, Team 13-5, Forte Fall 2013
CPSU-FORTE-F13S13G5
5 membres
17 tutoriels rédigés
4 commentaires
Very interesting, but my note 10.1 does not have these two screws adjacent to the charge point as you describe. So mine is a bit different. There are no screws anywhere on the tablet. So how do I take the back off mine ??
James Tobin - Réponse
It currently won’t start and I have read about a fix that requires the back to be removed.
What - How - Ware ? Yes I looked online for the parts, no I was not successful in finding the parts online. Can you tell me ware you found the parts for this project?
Brian Elling - Réponse
i need the panel
Ay Bami - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 22
Total : 39,151
