Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement, Front Glass/Digitizer: étape 1, image 1 de 1
    • I took pictures of the whole process but I forgot to get a pic of the broken phone. Here it is with the job completed.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 2, image 1 de 2 Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 2, image 2 de 2
    • The first steps are pretty simple.
    • Remove the battery cover, battery, SIM and MicroSD card.
    Demander à FixBot
  3. Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 3, image 1 de 2 Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 3, image 2 de 2
    • Pry off the top panel, refer to the images below for the locations of clips. Note: I found that the USB ports corners was a good place to lightly pry up- short side first.
    • This is the top panel after it was removed. There are three little tabs on this and a bunch of adhesive. I used a small flat head screwdriver on the pointy corner closest to the headphone jack and it popped right up. I slowly worked my way across and got the rest of the cover to pop up as well.
    • While lifting the cover I took my time, ensuring the adhesive wasn't damaged. It all stuck to the top cover as is evident in the second picture.
    Demander à FixBot
  4. Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 4, image 1 de 2 Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 4, image 2 de 2
    • There are six screws to remove from the rear of the phone and two from the top.
    Demander à FixBot
  5. Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 5, image 1 de 2 Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 5, image 2 de 2
    • The phone came apart pretty easily. I started on the bottom edge with a flat head screwdriver and carefully pried up the back cover. It opened easily until I got to the top section.
    • In the small gap indicated I inserted a small flat head screwdriver and turned it slowly. Once I opened this gap the rear case slipped off easily.
    Demander à FixBot
  6. Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 6, image 1 de 3 Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 6, image 2 de 3 Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 6, image 3 de 3
    • The first thing I removed was the battery. There is a plastic rim around the battery with a gap in one spot. I inserted a small flat head screwdriver in this gap to get under the battery and then popped the battery up and out. I left it connected to the main board.
    • Next you have four connectors to remove. I simply popped them off with my fingernail. Hook it underneath and gently lever them up.
    • The connector with the yellow and blue rectangle on it in the pic is the camera connector. When you lift this connector the camera will be free to remove.
    Demander à FixBot
  7. Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 7, image 1 de 1
    • The main board will now lift up easily from the chassis. There is one connector underneath that has to be removed. Again, a fingernail worked perfectly for me.
    • Once this connector was removed the main board was free from the rest of the phone.
    Demander à FixBot
  8. Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 8, image 1 de 2 Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 8, image 2 de 2
    • The next steps involved a bit of a battle. The chassis has to be separated from the front of the phone.
    • There are a number of clips holding the two pieces together. Again I used a small flat head screw driver to get the pieces to spread apart and then worked the two pieces apart gently... making sure not to damage anything.
    • Once all the pieces were separated I noticed that my LCD was stuck to the front of the phone. In some cases it may stick to the chassis. In my case this meant I had to wrestle the LCD off of the front. (see step 11)
    Demander à FixBot
  9. Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 9, image 1 de 1
    • The yellow rectangle indicates the microphone board. This should be removed to replace the digitizer. There are a couple of little clips to ply away from the board and this piece will pop out easily.
    • The LCD is indicated by the blue rectangle.
    Demander à FixBot
  10. Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 10, image 1 de 2 Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 10, image 2 de 2
    • This piece of blue tape has to be lifted to access the digitizer connector beneath.
    • The Yellow rectangle indicates the connector. The black piece has to be flipped up. Again, my fingernail worked fine here.
    • Once this is up the cable slips out easily and is quite easy to reinsert and lock back down.
    Demander à FixBot
  11. Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 11, image 1 de 1
    • To remove the LCD from the front panel I had to work carefully along the edges. I didn't want to break the LCD.
    • Once it loosened up a little I was able to slide a guitar pick along the two long edges to free the adhesive.
    Demander à FixBot
  12. Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 12, image 1 de 3 Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 12, image 2 de 3 Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 12, image 3 de 3
    • Here you see the front of the phone with the digitizer still attached.
    • The digitizer came out as one piece despite being horribly smashed.
    • I didn't use a heat gun but it would have helped a little. The digitizer was easy to remove without heat.
    Demander à FixBot
  13. Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 13, image 1 de 2 Samsung Galaxy W SGH-T679M Front Glass/Digitizer Replacement: étape 13, image 2 de 2
    • This little rubber part threatened to fall out on me but I pushed it back in place and never had another issue with it.
    • The installation is the reverse. It was very simple. The Digitizer I received had adhesive on it and fit perfectly. Once that was in place I had the phone back together in about 5 minutes.
    Demander à FixBot
12 autres ont terminé cette réparation.
Rene Jeddore
Membre depuis le 10/23/12
1 421 Réputation
3 tutoriels rédigés
13 commentaires de tutoriel
Nice Guide but... did you mean Exhibit 2 instead of Elite 2? :)
Simon - Réponse Partager
You are correct. I have fixed the guide.
Thanks!
Rene Jeddore - Réponse Partager
Thankyou so much Rene for doing this guide. I just finished replacing my digitizer. Just as you said, it was easy and cheap to find on ebay. I got the part and tools for under 11.00 with free shipping! I'm not the type of person that would try to do this repair on my own, but your step by step with pics made it easy.
Cheers,
Big Lar
Big Lar - Réponse Partager
Glad I helped!
Thanks! I just needed to remove the motherboard.
George
George Tedrick - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 56
Total : 14,508
