Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Watch4 Classic Display Replacement
Ce dont vous avez besoin
    1. Samsung Galaxy Watch4 Classic Display Replacement, Power down your watch: étape 1, image 1 de 1
      • Before starting repairs, take your watch off the charger and power it down.
      • Remove the watch band.
      Demander à FixBot
      Ajouter un commentaire
    2. Samsung Galaxy Watch4 Classic Display Replacement, Unscrew the back cover: étape 2, image 1 de 1
      • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
      Demander à FixBot
      • Insert an opening tool into the seam between the back cover and the metal housing.
      • Twist the opening tool to create a gap.
      • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
      Demander à FixBot
      • Lay the watch face down.
      • Carefully swing open the back cover by folding it to the opposite site of the created gap.
      • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
      • Remove the back cover.
      • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
      Demander à FixBot
      • Use the pointed end of a spudger to disconnect the hall sensor-, the display-, and the crown button flex cable.
      Demander à FixBot
    3. Samsung Galaxy Watch4 Classic Display Replacement, Unscrew the motherboard: étape 6, image 1 de 1
      • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
      Demander à FixBot
    4. Samsung Galaxy Watch4 Classic Display Replacement, Remove the motherboard: étape 7, image 1 de 3 Samsung Galaxy Watch4 Classic Display Replacement, Remove the motherboard: étape 7, image 2 de 3 Samsung Galaxy Watch4 Classic Display Replacement, Remove the motherboard: étape 7, image 3 de 3
      • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
      • During reassembly, make sure none of the flex cables become trapped underneath the motherbaord.
      Demander à FixBot
      • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
      • Twist and tilt the spudger to lever the core assembly out of the metal housing.
      • Thread the display flex cable through the opening in the core assembly.
      • Remove the core assembly.
      Demander à FixBot
    5. Samsung Galaxy Watch4 Classic Display Replacement, Heat the display: étape 9, image 1 de 1
      • Heat an iOpener and apply it to the display for two minutes to loosen the adhesive.
      Demander à FixBot
      • If your display is cracked, keep glass shards contained by applying a strip of tape over the glass.
      • Use your finger to steadily push the display down through the watch's metal housing to separate the display from the frame.
      • Remove the display.
      Demander à FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
6 autres ont terminé cette réparation.
Adriana Zwink
Membre depuis le 12/18/19
68 729 Réputation
167 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
86 246 tutoriels rédigés
1 commentaire de tutoriel
Where can I order the screen?
Scott Snyder - Réponse Partager
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 61
30 derniers jours : 288
Total : 19,736
