Aller au contenu principal
Samsung Galaxy Watch4 Core Assembly Removal
Ce dont vous avez besoin
  1. Samsung Galaxy Watch4 Core Assembly Removal, Power down your Galaxy Watch4: étape 1, image 1 de 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Samsung Galaxy Watch4 Core Assembly Removal, Unscrew the back cover: étape 2, image 1 de 1
    • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws.
  3. Samsung Galaxy Watch4 Core Assembly Removal, Wedge open the back cover: étape 3, image 1 de 2 Samsung Galaxy Watch4 Core Assembly Removal, Wedge open the back cover: étape 3, image 2 de 2
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. Samsung Galaxy Watch4 Core Assembly Removal, Disconnect the sensor flex cable: étape 4, image 1 de 2 Samsung Galaxy Watch4 Core Assembly Removal, Disconnect the sensor flex cable: étape 4, image 2 de 2
    • Lay the watch face down.
    • Carefully swing open the back cover by folding the back cover to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  5. Samsung Galaxy Watch4 Core Assembly Removal, Remove the back cover: étape 5, image 1 de 1
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
  6. Samsung Galaxy Watch4 Core Assembly Removal, Unscrew the motherboard: étape 6, image 1 de 1
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
  7. Samsung Galaxy Watch4 Core Assembly Removal, Disconnect the display flex cable: étape 7, image 1 de 2 Samsung Galaxy Watch4 Core Assembly Removal, Disconnect the display flex cable: étape 7, image 2 de 2
    • Use the flat end of a spudger to disconnect the display flex cable.
  8. Samsung Galaxy Watch4 Core Assembly Removal, Disconnect the side buttons: étape 8, image 1 de 2 Samsung Galaxy Watch4 Core Assembly Removal, Disconnect the side buttons: étape 8, image 2 de 2
    • Use a spudger to disconnect the flex cable of the crown buttons.
  9. Samsung Galaxy Watch4 Core Assembly Removal, Remove the motherboard: étape 9, image 1 de 2 Samsung Galaxy Watch4 Core Assembly Removal, Remove the motherboard: étape 9, image 2 de 2
    • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
  10. Samsung Galaxy Watch4 Core Assembly Removal, Lift the core assembly: étape 10, image 1 de 3 Samsung Galaxy Watch4 Core Assembly Removal, Lift the core assembly: étape 10, image 2 de 3 Samsung Galaxy Watch4 Core Assembly Removal, Lift the core assembly: étape 10, image 3 de 3
    • Place the corner of the flat end of a spudger under the plastic frame, on the opposite side of the display connector.
    • Twist and tilt the spudger to lever the core assembly out of the metal housing.
  11. Samsung Galaxy Watch4 Core Assembly Removal, Remove the core assembly: étape 11, image 1 de 1
    • Remove the core assembly.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
2 autres ont terminé cette réparation.
Adriana Zwink
Membre depuis le 12/18/19
56 600 Réputation
167 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 583 tutoriels rédigés
2 commentaires
I had the black screen of death and I wasn't getting anywhere with forced restarts, etc. My watch had gone blank and wouldn't even display charging level, though it did chime the noise when put on charge. Out of desperation I opened the case to look for water damage and to my surprise I found no damage or indication of water in the watch, aside from a small amount of corrosion on the aluminum case where it seals along the gasket, really just aluminum oxidation. After I put it all back together after pulling it apart looking for signs of water intrusion, the display finally functioned. My guess is disconnecting the motherboard from the battery gave the HARD reset I needed to get back in business. Thanks for the step by step guide to pull everything apart for exploratory surgery, it fixed my problem without needing to replace any components.
Westley Thayer - Réponse
Hi @westleythayer, thanks a lot for sharing your repair experience! I hope your smartwatch brings you endless enjoyment in the years ahead.
Adriana Zwink -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 18
30 derniers jours : 55
Total : 3,176
