Aller au contenu principal
Samsung Gear Fit Motherboard Replacement
Ce dont vous avez besoin
  1. Samsung Gear Fit Motherboard Replacement, Watch Band: étape 1, image 1 de 2 Samsung Gear Fit Motherboard Replacement, Watch Band: étape 1, image 2 de 2
    • Place your thumbs on the ends of the screen.
    • Push the watch outward while pulling the band away from the watch.
  2. Samsung Gear Fit Motherboard Replacement, Screen: étape 2, image 1 de 1
    • Heating the device with a hair dryer may warp the screen or damage the device. It it preferable to use an iOpener for this step.
    • For step-by-step instructions on using an iOpener, see the Instructions iOpener.
    • Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
  3. Samsung Gear Fit Motherboard Replacement: étape 3, image 1 de 3 Samsung Gear Fit Motherboard Replacement: étape 3, image 2 de 3 Samsung Gear Fit Motherboard Replacement: étape 3, image 3 de 3
    • The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful.
    • Gently pry the screen loose using a plastic opening tool.
    • If the screen doesn't easily come loose, more heating may be required
  4. Samsung Gear Fit Motherboard Replacement: étape 4, image 1 de 3 Samsung Gear Fit Motherboard Replacement: étape 4, image 2 de 3 Samsung Gear Fit Motherboard Replacement: étape 4, image 3 de 3
    • Using tweezers as a lever, pry the inner assembly out of the external casing.
    • This will be harder than removing the screen. Moderate force may be required.
  5. Samsung Gear Fit Motherboard Replacement: étape 5, image 1 de 3 Samsung Gear Fit Motherboard Replacement: étape 5, image 2 de 3 Samsung Gear Fit Motherboard Replacement: étape 5, image 3 de 3
    • Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
  6. Samsung Gear Fit Motherboard Replacement: étape 6, image 1 de 2 Samsung Gear Fit Motherboard Replacement: étape 6, image 2 de 2
    • Gently peel the screen assembly up and away from the device using tweezers.
  7. Samsung Gear Fit Motherboard Replacement, Motherboard: étape 7, image 1 de 3 Samsung Gear Fit Motherboard Replacement, Motherboard: étape 7, image 2 de 3 Samsung Gear Fit Motherboard Replacement, Motherboard: étape 7, image 3 de 3
    • Three ribbon cables hold the motherboard to the rest of the assembly.
    • The battery cable in the front.
    • When reassembling the device, make sure the battery cable is securely connected. Moderate force may be required to push it in all the way.
    • And two on the side.
    • Using a pair of tweezers, carefully pull each connector away to disconnect it from the rest of the assembly.
  8. Samsung Gear Fit Motherboard Replacement: étape 8, image 1 de 2 Samsung Gear Fit Motherboard Replacement: étape 8, image 2 de 2
    • The motherboard is a segmented three piece construction.
    • Use tweezers to first lift up, with a moderate amount of force, and free each ends of the motherboard from the assembly.
    • Be sure to use ESD safe tweezers to prevent static discharge from zapping your device.
  9. Samsung Gear Fit Motherboard Replacement: étape 9, image 1 de 1
    • The motherboard should now be removable from the assembly.
    • Use tweezers to lightly pry, lift, and remove the board by its middle section.
    • If the motherboard is stuck it may be caught on the assembly. Wiggle it around to free it. You may also need to pull the edges of the assembly away from the motherboard to create space.
2 autres ont terminé cette réparation.
Nathan Powell
Membre depuis le 04/24/14
1 577 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 11-49, Amido Spring 2014 Membre de l'équipe Cal Poly, Team 11-49, Amido Spring 2014
CPSU-AMIDO-S14S11G49
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 8
Total : 4,227
