Aller au contenu principal
Samsung Older French Door Refrigerator - Freezer Icemaker Replacement
Ce dont vous avez besoin
  1. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Unplug your refrigerator: étape 1, image 1 de 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Freezer Drawer (Older Model): étape 2, image 1 de 2 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Freezer Drawer (Older Model): étape 2, image 2 de 2
    • Open the freezer drawer.
  3. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement: étape 3, image 1 de 3 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement: étape 3, image 2 de 3 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement: étape 3, image 3 de 3
    • Pull out the upper freezer drawer.
    • Lift the front edge of the drawer.
    • Remove the drawer by lifting it up and out of the freezer compartment.
  4. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove small drawer basket: étape 4, image 1 de 3 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove small drawer basket: étape 4, image 2 de 3 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove small drawer basket: étape 4, image 3 de 3
    • Unclip the basket hinge retainer by tilting the rear edge up and remove it from the drawer rail.
    • Release the small drawer basket and lift it up and out.
  5. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove the drawer basket: étape 5, image 1 de 1
    • Lift the drawer basket out of the drawer frame and remove it.
  6. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Unfasten the drawer front: étape 6, image 1 de 2 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Unfasten the drawer front: étape 6, image 2 de 2
    • Use a 3/8" socket wrench, box wrench, or open end wrench to remove the bolts securing the drawer front to the right drawer slide.
    • Repeat the process for the left drawer slide.
  7. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove the drawer front: étape 7, image 1 de 3 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove the drawer front: étape 7, image 2 de 3 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove the drawer front: étape 7, image 3 de 3
    • Lift the drawer front upwards to free it from the drawer slides.
    • Remove the drawer front.
  8. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Release the connector rod retaining pin: étape 8, image 1 de 3 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Release the connector rod retaining pin: étape 8, image 2 de 3 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Release the connector rod retaining pin: étape 8, image 3 de 3
    • Rotate the slide connector rod until you can access the retaining pin.
    • Use a pair of long nose pliers to squeeze the retaining pin shank to release it.
  9. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove the drawer slide connecting rod: étape 9, image 1 de 2 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove the drawer slide connecting rod: étape 9, image 2 de 2
    • Pull the retaining pin out of the hole.
    • Slide the connecting rod to the right to free the left end of the rod.
    • Remove the rod by lifting it upward and sliding it back to the left.
  10. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Unfasten the freezer icemaker: étape 10, image 1 de 2 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Unfasten the freezer icemaker: étape 10, image 2 de 2
    • Use a #2 Phillips driver to remove the retaining screws.
    • Two views of the same screws are shown for clarity. There are not four screws.
  11. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Reposition the icemaker: étape 11, image 1 de 2 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Reposition the icemaker: étape 11, image 2 de 2
    • Pull the icemaker forward parallel to the top of the freezer.
    • This will release the icemaker from the freezer top.
    • Reposition the icemaker and hold it in one hand to prepare to disconnect it.
  12. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Disconnect the icemaker: étape 12, image 1 de 3 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Disconnect the icemaker: étape 12, image 2 de 3 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Disconnect the icemaker: étape 12, image 3 de 3
    • Grasp the icemaker connector (the one to the front) and squeeze the release tab.
    • Pull the connector out from the socket.
  13. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove the icemaker: étape 13, image 1 de 2 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove the icemaker: étape 13, image 2 de 2
    • Remove the ice maker.
    • This view shows the slots that the mounting studs on the freezer top for reference when reassembling.
Repair didn’t go as planned? Ask our Answers Community for help.
Bill Gilbert
Membre depuis le 06/30/22
37 443 Réputation
261 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 467 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 40
