Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Make sure you look at the Samsung P241 Troubleshooting Guide first to see if you can solve your problem without taking the DVD player apart.
Pièces
Aucune pièce spécifiée.
  1. You will need to be near a power source for this  guide. With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
    • You will need to be near a power source for this guide.
    • With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
  2. Manta Precision Bit Set
    112 embouts pour toute réparation.
    Upgrade Your Toolbox
  3. Pull the top cover towards you until you can lift it up and off. Pull the top cover towards you until you can lift it up and off.
    • Pull the top cover towards you until you can lift it up and off.
Sarah Wachtfogel
Membre depuis le 12/01/2011
340 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 14-7, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 14-7, Forte Winter 2011
CPSU-FORTE-W11S14G7
5 membres
7 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 374
