Aller au contenu principal
Samsung Refrigerator Door Sensors Replacement
Ce dont vous avez besoin
  1. Samsung Refrigerator Door Sensors Replacement, Unplug your refrigerator: étape 1, image 1 de 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Door Sensors Replacement, Remove the hinge cover: étape 2, image 1 de 1
    • Remove the screws securing the hinge cover (aka top table) on the top of the refrigerator.
  3. Samsung Refrigerator Door Sensors Replacement: étape 3, image 1 de 1
    • Lift the edges of the hinge cover to loosen it from the refrigerator.
    • Don't try to fully remove the cover, as it's still attached to the refrigerator by a few cables.
    • Flip the hinge cover over to access the cables underneath.
  4. Samsung Refrigerator Door Sensors Replacement: étape 4, image 1 de 2 Samsung Refrigerator Door Sensors Replacement: étape 4, image 2 de 2
    • Use your fingers to release the wire connectors under the hinge cover.
    • Disconnect the wiring so you can remove the hinge cover.
  5. Samsung Refrigerator Door Sensors Replacement: étape 5, image 1 de 1
    • Remove the hinge cover.
  6. Samsung Refrigerator Door Sensors Replacement, Sensor information: étape 6, image 1 de 2 Samsung Refrigerator Door Sensors Replacement, Sensor information: étape 6, image 2 de 2
    • The door sensors are located in the hinge cover. In this example, the hinge cover has two door sensors:
    • The left door sensor
    • The left door sensor connector
    • The right door sensor
    • The right door sensor connector
    • Depending on your situation, you may need to replace either or both sensors.
  7. Samsung Refrigerator Door Sensors Replacement, Remove the sensor: étape 7, image 1 de 2 Samsung Refrigerator Door Sensors Replacement, Remove the sensor: étape 7, image 2 de 2
    • Use your fingers to squeeze and disconnect the sensor cable connector.
  8. Samsung Refrigerator Door Sensors Replacement: étape 8, image 1 de 2 Samsung Refrigerator Door Sensors Replacement: étape 8, image 2 de 2
    • Use a spudger or a flathead screwdriver to pry the sensor out of its retaining clips.
  9. Samsung Refrigerator Door Sensors Replacement: étape 9, image 1 de 1
    • Remove the door sensor.
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
Membre depuis le 04/14/15
15 927 Réputation
88 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
33 membres
577 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 79
30 derniers jours : 428
Total : 2,790
