Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Refrigerator Evaporator Drain Clip Replacement
Ce dont vous avez besoin
  1. Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: étape 1, image 1 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: étape 1, image 2 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: étape 1, image 3 de 3
    • Using a spudger, pry off the cap covering the topmost screw.
  2. Samsung Refrigerator Evaporator Drain Clip Replacement: étape 2, image 1 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement: étape 2, image 2 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement: étape 2, image 3 de 3
    • Remove three 12.7 mm screws using a Phillips #0 screwdriver.
  3. Samsung Refrigerator Evaporator Drain Clip Replacement: étape 3, image 1 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement: étape 3, image 2 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement: étape 3, image 3 de 3
    • Use your hands or a spudger to pry back the plastic cover starting from the bottom.
    • Once all the clips are pulled out, loosen the cover by pushing it slightly up and out.
    • Do not pull the cover off yet; there are still connectors attaching the cover to the fridge.
  4. Samsung Refrigerator Evaporator Drain Clip Replacement: étape 4, image 1 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement: étape 4, image 2 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement: étape 4, image 3 de 3
    • Gently unplug both connectors.
    • Remember their orientations as it will be important during reassembly.
  5. Samsung Refrigerator Evaporator Drain Clip Replacement: étape 5, image 1 de 1
    • Using a hair dryer or heat gun, melt down any ice buildup in the draining well.
  6. Samsung Refrigerator Evaporator Drain Clip Replacement: étape 6, image 1 de 1
    • Cut out the old evaporating clip using a pair of cutting pliers.
  7. Samsung Refrigerator Evaporator Drain Clip Replacement: étape 7, image 1 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement: étape 7, image 2 de 3 Samsung Refrigerator Evaporator Drain Clip Replacement: étape 7, image 3 de 3
    • Replace the old clip with a new evaporating clip.
8 autres ont terminé cette réparation.
Deep Patel
Membre depuis le 09/15/20
320 Réputation
1 tutoriel rédigé
Équipe
York University, Team S3-G60, Melo-Thaiss Fall 2020 Membre de l'équipe York University, Team S3-G60, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S3G60
1 membre
2 tutoriels rédigés
3 commentaires de tutoriel
you rock!!!@
Marie Przehorski - Réponse Partager
Problem only resolved for about 6 months post clip replacement. Now every 2 months back to defrosting my refrigerator, under the crisper drawer. Now the entire section of the drain is frozen. Very frustraing.
David Kahan - Réponse Partager
Here's another video of this replacement. Head over to the refrigerator leaking water wiki for more fixes for freezing lines.
nicO - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 94
30 derniers jours : 402
Total : 22,705
