Aller au contenu principal
Sanyo VPC-T850 Photo Array Device Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Sanyo VPC-T850 Photo Array Device Replacement, Disassembling Sanyo VPC-T850 Outer Casing: étape 1, image 1 de 1
    • Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
    • Locate the battery hatch on the bottom-right side of the camera and slide it outwards to open.
    • In the compartment, move the small notch and push down on the battery to remove it.
    • During reassembly, there is an arrow on the battery hatch indicating which way it goes in.
  2. Sanyo VPC-T850 Photo Array Device Replacement, Remove Screws: étape 2, image 1 de 3 Sanyo VPC-T850 Photo Array Device Replacement, Remove Screws: étape 2, image 2 de 3 Sanyo VPC-T850 Photo Array Device Replacement, Remove Screws: étape 2, image 3 de 3
    • Remove the eight screws around the sides and bottom of the camera using a Phillips #00 screwdriver.
  3. Sanyo VPC-T850 Photo Array Device Replacement, Remove Rear Panel: étape 3, image 1 de 3 Sanyo VPC-T850 Photo Array Device Replacement, Remove Rear Panel: étape 3, image 2 de 3 Sanyo VPC-T850 Photo Array Device Replacement, Remove Rear Panel: étape 3, image 3 de 3
    • Using the spudger, gently pry the rear panel away from the left side.
    • Be careful not to damage the three green cables as you remove the rear panel of the camera.
  4. Sanyo VPC-T850 Photo Array Device Replacement: étape 4, image 1 de 1
    • Using the Phillips #00 screwdriver, remove the eight black screws connecting the green keypad chip to the rear panel.
    • Do not put any excessive force on the green wires.
  5. Sanyo VPC-T850 Photo Array Device Replacement: étape 5, image 1 de 1
    • Separate the rear panel from the rest of the camera.
  6. Sanyo VPC-T850 Photo Array Device Replacement: étape 6, image 1 de 2 Sanyo VPC-T850 Photo Array Device Replacement: étape 6, image 2 de 2
    • Using the Phillips #00 screwdriver, remove the 3 screws located across the top of the camera.
    • Separate the black plastic panel from the camera. The camera button will be attached, so be gentle.
  7. Sanyo VPC-T850 Photo Array Device Replacement: étape 7, image 1 de 2 Sanyo VPC-T850 Photo Array Device Replacement: étape 7, image 2 de 2
    • Carefully pull off the side covers wrapped around the camera.
  8. Sanyo VPC-T850 Photo Array Device Replacement, Remove Front Cover: étape 8, image 1 de 3 Sanyo VPC-T850 Photo Array Device Replacement, Remove Front Cover: étape 8, image 2 de 3 Sanyo VPC-T850 Photo Array Device Replacement, Remove Front Cover: étape 8, image 3 de 3
    • Using the spudger, gently lift off the front cover of the camera.
    • The front cover is fragile, so be gentle when removing it. It can easily break if not removed carefully.
  9. Sanyo VPC-T850 Photo Array Device Replacement, Disconnect the Ribbon: étape 9, image 1 de 2 Sanyo VPC-T850 Photo Array Device Replacement, Disconnect the Ribbon: étape 9, image 2 de 2
    • Use caution not to damage ribbon when disconnecting.
    • The yellow ribbon is attached to the right side of the screen and goes to a black connector piece.
    • Gently flip the black connector away from the LCD screen to unlock the yellow ribbon.
    • Carefully pull the yellow ribbon towards the LCD screen to disconnect it.
  10. Sanyo VPC-T850 Photo Array Device Replacement, Remove LCD Screen: étape 10, image 1 de 1
    • The LCD screen should now be disconnected from the rest of the camera and a pry tool can be used to lift it out of its casing.
  11. Sanyo VPC-T850 Photo Array Device Replacement, Photo Array Device: étape 11, image 1 de 1
    • Remove the two screws holding the photo array.
  12. Sanyo VPC-T850 Photo Array Device Replacement: étape 12, image 1 de 3 Sanyo VPC-T850 Photo Array Device Replacement: étape 12, image 2 de 3 Sanyo VPC-T850 Photo Array Device Replacement: étape 12, image 3 de 3
    • Remove the foam from the top of the wire connector.
    • Gently remove the plastic connector in the same way as the previous connector of the same type.
    • Lift the connector from the side with the ribbon cable in it.
    • Using the spudger, gently push from the right side.
Jonathan Yau
Membre depuis le 04/11/10
26 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 27-95, Amido Spring 2010 Membre de l'équipe Cal Poly, Team 27-95, Amido Spring 2010
CPSU-AMIDO-S10S27G95
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 2,101
