Aller au contenu principal
Sega Dreamcast Power Supply Replacement
Ce dont vous avez besoin
  1. Sega Dreamcast Power Supply Replacement, Expansion Bay: étape 1, image 1 de 2 Sega Dreamcast Power Supply Replacement, Expansion Bay: étape 1, image 2 de 2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Power Supply Replacement: étape 2, image 1 de 3 Sega Dreamcast Power Supply Replacement: étape 2, image 2 de 3 Sega Dreamcast Power Supply Replacement: étape 2, image 3 de 3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Power Supply Replacement, Top Cover: étape 3, image 1 de 1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Power Supply Replacement: étape 4, image 1 de 1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast Power Supply Replacement, Power Supply: étape 5, image 1 de 2 Sega Dreamcast Power Supply Replacement, Power Supply: étape 5, image 2 de 2
    • Unplug the device from the outlet. If you have just powered off the system, allow a few minutes for the capacitors to discharge before you begin working.
    • Remove the white female pin head by pinching and lifting directly up on the harness.
    • Remove the two Philips #02 screws from the board.
    • Remove the power board. Using both hands, gently lift the power board away from the console without damaging the male pin head
  6. Sega Dreamcast Power Supply Replacement: étape 6, image 1 de 2 Sega Dreamcast Power Supply Replacement: étape 6, image 2 de 2
    • Remove the unit. Carefully remove the power board from the console by lightly grasping the board by the edge and lifting directly upward.
    • Remove the two 10mm #02 Philips screws to detach the switch module from the console.
    • Purchase a replacement power board.
6 autres ont terminé cette réparation.
Jacks216
Membre depuis le 11/25/09
103 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 5-1, Regan Fall 2009 Membre de l'équipe Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 membres
21 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 60
Total : 17,372
