Aller au contenu principal
Sennheiser HD 4.50 Battery Replacement
Ce dont vous avez besoin
  1. Sennheiser HD 4.50 Battery Replacement, Battery: étape 1, image 1 de 1
    • Locate the side designation on the headband-earpiece junction.
    • The battery is on the left side.
    • The motherboard is on the right side.
  2. Sennheiser HD 4.50 Battery Replacement: étape 2, image 1 de 3 Sennheiser HD 4.50 Battery Replacement: étape 2, image 2 de 3 Sennheiser HD 4.50 Battery Replacement: étape 2, image 3 de 3
  3. Sennheiser HD 4.50 Battery Replacement: étape 3, image 1 de 3 Sennheiser HD 4.50 Battery Replacement: étape 3, image 2 de 3 Sennheiser HD 4.50 Battery Replacement: étape 3, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the four 10 mm screws holding the ear cup cover in place.
    • Use an opening tool to pry open the cover.
    • Remove the cover.
  4. Sennheiser HD 4.50 Battery Replacement: étape 4, image 1 de 1
    • Use a spudger to pry the battery from the plastic case.
    • The battery is held down by a strong adhesive, so it will give resistance. You can apply a few drops of high concentration (>90%) isopropyl alcohol to the base of the battery to loosen it.
  5. Sennheiser HD 4.50 Battery Replacement: étape 5, image 1 de 2 Sennheiser HD 4.50 Battery Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using tweezers, pull the white battery connector upwards out of its socket.
    • Remove the battery.
    • Silicone sealant and foam tape has been used to segregate the two compartments. This will rip when the cable is removed. It can be replaced with fresh silicone if desired.
7 autres ont terminé cette réparation.
Grace Singley
Membre depuis le 02/19/21
601 Réputation
5 tutoriels rédigés
Équipe
6 commentaires
Hello ! Thanks for the tuto. Do you know where to buy the battery ?
Fren6 - Réponse
You can search with the part number(Shown in the photo) : AHB622540N1/AHB622540N01.
Santanu Ghosal - Réponse
Where i can find it
Erik Ridwan -
Does anyone know if I can use the he 450 bt replacement battery in a 350 bt headphone? The difference in the spec is that the 450’s battery has a longer battery life (2.2 wh vs. 1.3 wh)
M Lawson - Réponse
This was pretty straightforward, but in opening the cap one of the tiny soldered wires pulled off the pad. It's so tiny that I don't have much hope of soldering it back. Any other way to reattach it? I put it back together anyways and now the right cup works fine, but the left is dead. I recommend a warning here about the little wires, if nothing else.
David Hook - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 17
7 derniers jours : 138
30 derniers jours : 579
Total : 14,235
