Introduction
The XLR Connector is the part of the microphone that plugs into the cable which carries the sound to the sound mixer and speakers.
Outils
Pièces
Aucune pièce spécifiée.
Using a small flat head screwdriver, gently turn the retaining screw at the bottom of the microphone counterclockwise until it stops or provides resistance.
Bend the wire around the contact point. Pin numbers are located on the outside of the connector.
Connect the red wire to Pin 3 and the blue wire to Pin 2.
Pin 1 should have a single piece of exposed wire connecting it to the metal plate on the top of the connector (the ground plate).
To reinstall the XLR connector, follow the Installing Shure SM58 XLR connector guide
After soldering the wires to the XLR connector and reassembling your microphone, your microphone should be ready to plug in to the XLR cable and function properly.
3 autre(s) ont terminé cette réparation.
7 commentaires
I'm not familiar with the "pin 2 hot method." We took a working mic apart and reassembled it the way we found it, so I'm pretty that is the correct soldering configuration.
Świetna strona. Brawo.
