Aller au contenu principal
Skateboard Skateboard Trucks Replacement
Ce dont vous avez besoin
  1. Skateboard Skateboard Trucks Replacement, Skateboard Trucks: étape 1, image 1 de 2 Skateboard Skateboard Trucks Replacement, Skateboard Trucks: étape 1, image 2 de 2
    • Insert bolt hardware through the factory drilled holes from the top side of the skateboard.
    • If you have a riser and would like to install it, please reference the Wheel Bite Prevention guide.
  2. Skateboard Skateboard Trucks Replacement: étape 2, image 1 de 1
    • Slide the truck onto the four protruding bolt hardware screws, while using your hand to prevent the screws from popping out the top of the skateboard.
  3. Skateboard Skateboard Trucks Replacement: étape 3, image 1 de 1
    • Hand tighten the nut hardware onto all four bolts.
  4. Skateboard Skateboard Trucks Replacement: étape 4, image 1 de 1
    • While holding the nuts on the bottom side of the skateboard in place with the 3/8" wrench, tighten the screws from the top side of the skateboard with a screwdriver. Tighten the screws in a diagonal pattern until the head of the screw sinks slightly into the grip tape.
    • Repeat steps 1 - 6 to install the second truck.
To uninstall your trucks, simply follow these steps in reverse order. To continue assembling your skateboard deck, see the Wheel Installation guide.
2 autres ont terminé cette réparation.
Cameron Nye
Membre depuis le 10/03/12
79 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 6-32, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 6-32, Regan Fall 2012
CPSU-REGAN-F12S6G32
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 13,393
