Aller au contenu principal
Skullcandy Crusher Wireless Battery Replacement
Ce dont vous avez besoin
  1. Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: étape 1, image 1 de 2 Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: étape 1, image 2 de 2
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Battery Replacement: étape 2, image 1 de 2 Skullcandy Crusher Wireless Battery Replacement: étape 2, image 2 de 2
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Battery Replacement: étape 3, image 1 de 1
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Battery Replacement, Battery: étape 4, image 1 de 2 Skullcandy Crusher Wireless Battery Replacement, Battery: étape 4, image 2 de 2
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
    • You have to work on the right-side earphone.
  5. Skullcandy Crusher Wireless Battery Replacement: étape 5, image 1 de 3 Skullcandy Crusher Wireless Battery Replacement: étape 5, image 2 de 3 Skullcandy Crusher Wireless Battery Replacement: étape 5, image 3 de 3
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker part away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Battery Replacement: étape 6, image 1 de 2 Skullcandy Crusher Wireless Battery Replacement: étape 6, image 2 de 2
    • Separate the headphone speaker assembly from the headphone speaker frame.
  7. Skullcandy Crusher Wireless Battery Replacement: étape 7, image 1 de 3 Skullcandy Crusher Wireless Battery Replacement: étape 7, image 2 de 3 Skullcandy Crusher Wireless Battery Replacement: étape 7, image 3 de 3
    • Remove the battery from the headphone housing.
    • Use a soldering iron to desolder the black, red, and yellow cables from the board and disconnect the battery.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
4 autres ont terminé cette réparation.
Val
Membre depuis le 03/31/22
1 080 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-33, Gurgel Spring 2022 Membre de l'équipe UMass Dartmouth, Team 1-33, Gurgel Spring 2022
UMASSD-GURGEL-S22S1G33
1 membre
12 tutoriels rédigés
4 commentaires
Hi, Can you specify this replacement batterys name and model number?
kituserkituserkituser kit - Réponse
1050mAh, 3,7V 3,885Wh
Mika Björn Wilhelmsen -
Which battery should i buy for my skull candy hes evo??
Lakshit Meena - Réponse
donde puedo conseguir la bateria de los skullcandy crusher?
y cual bateria lleva?
pedro landeros - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 72
30 derniers jours : 364
Total : 8,904
