Aller au contenu principal
Sonos Roam Outer Circuit Board Replacement
Ce dont vous avez besoin
  1. Sonos Roam Outer Circuit Board Replacement, End Caps: étape 1, image 1 de 3 Sonos Roam Outer Circuit Board Replacement, End Caps: étape 1, image 2 de 3 Sonos Roam Outer Circuit Board Replacement, End Caps: étape 1, image 3 de 3
    • Power off your Sonos Roam before beginning disassembly.
    • Use the metal spudger to pry the end cap with the buttons.
    • Pry from all sides to loosen the adhesive.
    • Use the iOpener, a blowdryer, or a similar heating device to loosen the adhesive if having difficulty.
  2. Sonos Roam Outer Circuit Board Replacement: étape 2, image 1 de 2 Sonos Roam Outer Circuit Board Replacement: étape 2, image 2 de 2
    • Flip the device to the other end cap.
    • Use the metal spudger to loosen the adhesive.
  3. Sonos Roam Outer Circuit Board Replacement, Speaker Grille: étape 3, image 1 de 2 Sonos Roam Outer Circuit Board Replacement, Speaker Grille: étape 3, image 2 de 2
    • Flip the device so that the Sonos logo is on the top.
    • Use the Torx T6 screwdriver to remove the two 6 mm screws.
  4. Sonos Roam Outer Circuit Board Replacement: étape 4, image 1 de 2 Sonos Roam Outer Circuit Board Replacement: étape 4, image 2 de 2
    • Flip the device.
  5. Sonos Roam Outer Circuit Board Replacement: étape 5, image 1 de 3 Sonos Roam Outer Circuit Board Replacement: étape 5, image 2 de 3 Sonos Roam Outer Circuit Board Replacement: étape 5, image 3 de 3
    • Flip the device so the Sonos logo is on the top.
    • Use the iFixit opening picks to wedge between the split of the grille and the back of the speaker to pry the grille apart.
  6. Sonos Roam Outer Circuit Board Replacement, Speaker Module: étape 6, image 1 de 2 Sonos Roam Outer Circuit Board Replacement, Speaker Module: étape 6, image 2 de 2
    • Use the TR10 Torx screwdriver to remove the six 7 mm screws.
  7. Sonos Roam Outer Circuit Board Replacement: étape 7, image 1 de 3 Sonos Roam Outer Circuit Board Replacement: étape 7, image 2 de 3 Sonos Roam Outer Circuit Board Replacement: étape 7, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Begin to carefully separate the speaker module from the device.
    • Firmly squeeze the middle of the plug using the tweezers to pull it out of the socket.
    • Separate the speaker module from the device.
  8. Sonos Roam Outer Circuit Board Replacement, Outer Circuit Board: étape 8, image 1 de 2 Sonos Roam Outer Circuit Board Replacement, Outer Circuit Board: étape 8, image 2 de 2
    • Use the TR10 Torx screwdriver to remove the four 7 mm screws.
  9. Sonos Roam Outer Circuit Board Replacement: étape 9, image 1 de 3 Sonos Roam Outer Circuit Board Replacement: étape 9, image 2 de 3 Sonos Roam Outer Circuit Board Replacement: étape 9, image 3 de 3
    J'achète
    • Use the tweezers to flip the latch holding the large ribbon in place.
    • Grab the large ribbon with the tweezers and pull upwards to remove it.
    • Use the tweezers to flip the latch holding the small ribbon in place.
    • Grab the small ribbon with the tweezers and pull upwards to remove it.
  10. Sonos Roam Outer Circuit Board Replacement: étape 10, image 1 de 3 Sonos Roam Outer Circuit Board Replacement: étape 10, image 2 de 3 Sonos Roam Outer Circuit Board Replacement: étape 10, image 3 de 3
    • Grab the metal piece sticking out of the outer circuit board.
    • Pull upwards to remove the outer circuit board.
  11. Sonos Roam Outer Circuit Board Replacement: étape 11, image 1 de 2 Sonos Roam Outer Circuit Board Replacement: étape 11, image 2 de 2
    • Soldering Iron is very hot and can cause injury if not used properly.
    • Use a soldering iron to desolder the outer circuit board from the speaker casing.
Lauren Young
Membre depuis le 09/20/23
584 Réputation
5 tutoriels rédigés
Équipe
Utah Tech University, Team 1-2, McMurrin Fall 2023 Membre de l'équipe Utah Tech University, Team 1-2, McMurrin Fall 2023
UTAHTECH-MCMURRIN-F23S1G2
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 27
Total : 177
