Aller au contenu principal
Sony BDP-S3500 Disk Drive Replacement
Ce dont vous avez besoin
  1. Sony BDP-S3500 Disk Drive Replacement, Front Panel: étape 1, image 1 de 2 Sony BDP-S3500 Disk Drive Replacement, Front Panel: étape 1, image 2 de 2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Disk Drive Replacement: étape 2, image 1 de 1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Disk Drive Replacement: étape 3, image 1 de 2 Sony BDP-S3500 Disk Drive Replacement: étape 3, image 2 de 2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
  4. Sony BDP-S3500 Disk Drive Replacement, Disk Drive: étape 4, image 1 de 2 Sony BDP-S3500 Disk Drive Replacement, Disk Drive: étape 4, image 2 de 2
    • Remove the three ribbon cables by gently pulling the cables out of each connector.
    • Be sure to only handle the circuit board from the edges so that the PCB is not damaged.
  5. Sony BDP-S3500 Disk Drive Replacement: étape 5, image 1 de 2 Sony BDP-S3500 Disk Drive Replacement: étape 5, image 2 de 2
    • Use a Phillips #2 screwdriver to remove the two 9mm screws that are holding the disk drive in place.
  6. Sony BDP-S3500 Disk Drive Replacement: étape 6, image 1 de 2 Sony BDP-S3500 Disk Drive Replacement: étape 6, image 2 de 2
    • Carefully lift and slide the disk drive out of the casing.
V W
Membre depuis le 01/22/20
197 Réputation
1 tutoriel rédigé
Équipe
York University, Team S8-G4, Turner Winter 2020 Membre de l'équipe York University, Team S8-G4, Turner Winter 2020
YORK-TURNER-W20S8G4
4 membres
5 tutoriels rédigés
Un commentaire
Hello, great guide thank you. How do you go about finding the correct replacement drive?
Andy Day - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 12
Total : 394
