Aller au contenu principal
Sony BDP-S3500 Port Board Replacement
Ce dont vous avez besoin
  1. Sony BDP-S3500 Port Board Replacement, Front Panel: étape 1, image 1 de 2 Sony BDP-S3500 Port Board Replacement, Front Panel: étape 1, image 2 de 2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Port Board Replacement: étape 2, image 1 de 1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Port Board Replacement: étape 3, image 1 de 2 Sony BDP-S3500 Port Board Replacement: étape 3, image 2 de 2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
  4. Sony BDP-S3500 Port Board Replacement, Port Board: étape 4, image 1 de 2 Sony BDP-S3500 Port Board Replacement, Port Board: étape 4, image 2 de 2
    • Keep the back side up and facing towards you.
    • Carefully disconnect the blue ribbon connecting the port board and motherboard.
    • Be delicate while removing the ribbon.
  5. Sony BDP-S3500 Port Board Replacement: étape 5, image 1 de 1
    • Use a Phillips #2 screwdriver to remove the 9mm screw from the port board.
  6. Sony BDP-S3500 Port Board Replacement: étape 6, image 1 de 1
    • Remove the port board from the device.
Megh Ladumor
Membre depuis le 01/22/20
100 Réputation
1 tutoriel rédigé
Équipe
York University, Team S8-G4, Turner Winter 2020 Membre de l'équipe York University, Team S8-G4, Turner Winter 2020
YORK-TURNER-W20S8G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 296
