Aller au contenu principal
Sony BDP-s7200 Front Panel Board Replacement
Ce dont vous avez besoin
  1. Sony BDP-s7200 Front Panel Board Replacement, Back Cover: étape 1, image 1 de 1
    • Remove the disk tray cover from the device.
  2. Sony BDP-s7200 Front Panel Board Replacement: étape 2, image 1 de 2 Sony BDP-s7200 Front Panel Board Replacement: étape 2, image 2 de 2
    • Using the Phillips #2 Screwdriver, remove the five 9mm from the bottom of the device.
    • Remove the metal cover.
  3. Sony BDP-s7200 Front Panel Board Replacement: étape 3, image 1 de 2 Sony BDP-s7200 Front Panel Board Replacement: étape 3, image 2 de 2
    • Using the Phillips #2 Screwdriver, remove the six 9mm screws from the back of the device.
  4. Sony BDP-s7200 Front Panel Board Replacement: étape 4, image 1 de 1
    • Pull off the back panel and remove it from the device.
  5. Sony BDP-s7200 Front Panel Board Replacement, Front Panel Cover: étape 5, image 1 de 3 Sony BDP-s7200 Front Panel Board Replacement, Front Panel Cover: étape 5, image 2 de 3 Sony BDP-s7200 Front Panel Board Replacement, Front Panel Cover: étape 5, image 3 de 3
    • Using the plastic opening tool, open one of the tabs on the bottom of the device.
    • While keeping the tab open, insert a opening pick in between the opening tool and tab.
    • Repeat this for the 3 other tabs.
  6. Sony BDP-s7200 Front Panel Board Replacement: étape 6, image 1 de 2 Sony BDP-s7200 Front Panel Board Replacement: étape 6, image 2 de 2
    • Place your hands on the two black circles on the bottom of the device.
    • Pull on the black circles to remove the device from its front panel cover.
  7. Sony BDP-s7200 Front Panel Board Replacement: étape 7, image 1 de 3 Sony BDP-s7200 Front Panel Board Replacement: étape 7, image 2 de 3 Sony BDP-s7200 Front Panel Board Replacement: étape 7, image 3 de 3
    • Using the Phillips #2 Screwdriver, remove the seven 9mm screws from the top of the device.
    • Using the same screwdriver, remove the three 9mm screws from the back of the device.
    • Using the same screwdriver, remove the one 9mm screw still connecting the small metal clip to the front of the device.
  8. Sony BDP-s7200 Front Panel Board Replacement: étape 8, image 1 de 2 Sony BDP-s7200 Front Panel Board Replacement: étape 8, image 2 de 2
    • Remove the small metal clip on the front of the device.
    • Remove the metal cover on the top of the device.
  9. Sony BDP-s7200 Front Panel Board Replacement, Front Panel Board: étape 9, image 1 de 2 Sony BDP-s7200 Front Panel Board Replacement, Front Panel Board: étape 9, image 2 de 2
    • Unplug the large ribbon cable connecting the front panel board to the motherboard.
  10. Sony BDP-s7200 Front Panel Board Replacement: étape 10, image 1 de 1
    • Unplug the small ribbon cable connecting the front panel board to the smaller board to the left of it.
    • Using the Phillips #2 Screwdriver, remove the one 9mm screw connecting the front panel board to the device.
    • Remove the front panel board.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 155
